    Help needed: Arduino Wireless Notice Board project
    7039
      arunksoman @rafitc99 last edited by
      @rafitc99 Please answer my question...
      1. Why did u declared message as const? Const indicates you are not going to change that variable any more.
      Try to use c_str() instead to_charArray()
      Reference
        @rafitc99 , @SAFVAN did you tried the @arunksoman suggestion?
          SAFVAN last edited by
          Now message is displaying with mobile number, date, time.
          I want filter the actual message only.
            salmanfaris @SAFVAN last edited by
            @SAFVAN what was the solution with the previous problem?
              rafitc99 @salmanfaris last edited by
              @salmanfaris tried @arunksoman suggestion , c_str() instead to_charArray().. But want to parse SMS body only. Now working on that.
              C 1 Reply Last reply Reply Quote 1
                codelery @rafitc99 last edited by
                @rafitc99 what is the final code? Could you please share it with us? I have been battling with a similar project.
                Which Arduino board did you use?
                thanks
                  rafitc99 @codelery last edited by
                  @codelery You can use any Arduino board. So far as i remember, we used Arduino UNO.
                  Somehow i found the code in my gist. It was a 3 year old project. So, i don't remember most of the things
                  Code:
                  #include <SoftwareSerial.h>
                  #include <SPI.h>
                  #include <DMD.h>
                  #include <TimerOne.h>
                  #include "SystemFont5x7.h"
                  #include "Arial_black_16.h"
                  #define ROW 1
                  #define COLUMN 1
                  #define FONT Arial_Black_16
                  DMD led_module(ROW, COLUMN);
                  String st;
                  const char *msg;
                  unsigned int LengMsg;
                  char finalMsg[100] = "";
                  SoftwareSerial mySerial(3, 2);
                  void scan_module() {
                    led_module.scanDisplayBySPI();
                    Timer1.initialize(2000);
                    Timer1.attachInterrupt(scan_module);
                    led_module.clearScreen( true );
                    mySerial.begin(9600);
                    Serial.println("Starting...");
                    delay(1000);
                    mySerial.println("AT");
                    updateSerial();
                    mySerial.println("AT+CMGF=1");
                    updateSerial();
                    mySerial.println("AT+CNMI=1,2,0,0,0");
                    updateSerial();
                    //  pollSms();
                    displayMessage();
                    delay(500);
                    //Start print in led matrix
                    led_module.selectFont(FONT);
                    led_module.drawMarquee(finalMsg, LengMsg, (32 * ROW), 0);
                    long start = millis();
                    long timming = start;
                    boolean flag = false;
                    while (!flag) {
                      if ((timming + 20) < millis()) {
                        flag = led_module.stepMarquee(-1, 0);
                        timming = millis();
                  //------GSM Helper
                  void displayMessage()
                    delay(500);
                    String msg = "";
                    int start = 0, endPoint = 0;
                    finalMsg[100] = "";
                    while (Serial.available())
                      mySerial.write(Serial.read());//Forward what Serial received to Software Serial Port
                      //     parseData(mySerial.readString());//Calls the parseData function to parse SMS
                    while (mySerial.available())
                      msg = mySerial.readString();//Forward what Software Serial received to Serial Port
                    if (msg.length() > 1) {
                      start = msg.indexOf('*') + 1;
                      endPoint = msg.indexOf('#') - 1;
                      int count = 0;
                      if (start > 1 && endPoint > 1) {
                        strcpy( finalMsg, "");
                        for (int i = start; i <= endPoint; i++) {
                          finalMsg[count] = msg[i];
                          count++;
                        Serial.println("SMS Received: ");
                        Serial.println(finalMsg);
                        LengMsg = count;
                      else{
                        return false;
                  void updateSerial()
                    delay(500);
                      Serial.write(mySerial.read());//Forward what Software Serial received to Serial Port
                  NB: The sms body should be between start and hash
                  Eg: * Hello Makers! #
                  C 2 Replies Last reply Reply Quote 0
                    @rafitc99 thank you so much. I will try it out and see if it will work.
                      This post is deleted!
                        @rafitc99 I tried this code, but the SMS is always corrupted. I got "Hello peopl⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮
                        instead of "Hello people of the village who work day and night to make sure all is well"
