    Help needed: Arduino Wireless Notice Board project
    7557
      Can you print the SMS on the serial monitor too? so we can conclude the problem
      rafitc99 1 Reply Last reply Reply Quote 0
        rafitc99 @salmanfaris last edited by
        @salmanfaris in serial monitor getting normal text. No problem in there.
          salmanfaris @rafitc99 last edited by
          @rafitc99 Okay, it might be sending char from SMS buffer to LED panel. let me check, I'll get back to you.
            arunksoman @rafitc99 last edited by
            @rafitc99 Please answer my question...
            1. Why did u declared message as const? Const indicates you are not going to change that variable any more.
            Try to use c_str() instead to_charArray()
            Reference
              @rafitc99 , @SAFVAN did you tried the @arunksoman suggestion?
                SAFVAN last edited by
                Now message is displaying with mobile number, date, time.
                I want filter the actual message only.
                  salmanfaris @SAFVAN last edited by
                  @SAFVAN what was the solution with the previous problem?
                    @salmanfaris tried @arunksoman suggestion , c_str() instead to_charArray().. But want to parse SMS body only. Now working on that.
                    C 1 Reply Last reply Reply Quote 1
                      codelery @rafitc99 last edited by
                      @rafitc99 what is the final code? Could you please share it with us? I have been battling with a similar project.
                      Which Arduino board did you use?
                      thanks
                        rafitc99 @codelery last edited by
                        @codelery You can use any Arduino board. So far as i remember, we used Arduino UNO.
                        Somehow i found the code in my gist. It was a 3 year old project. So, i don't remember most of the things
                        Code:
                        #include <SoftwareSerial.h>
                        #include <SPI.h>
                        #include <DMD.h>
                        #include <TimerOne.h>
                        #include "SystemFont5x7.h"
                        #include "Arial_black_16.h"
                        #define ROW 1
                        #define COLUMN 1
                        #define FONT Arial_Black_16
                        DMD led_module(ROW, COLUMN);
                        String st;
                        const char *msg;
                        unsigned int LengMsg;
                        char finalMsg[100] = "";
                        SoftwareSerial mySerial(3, 2);
                        void scan_module() {
                          led_module.scanDisplayBySPI();
                          Timer1.initialize(2000);
                          Timer1.attachInterrupt(scan_module);
                          led_module.clearScreen( true );
                          mySerial.begin(9600);
                          Serial.println("Starting...");
                          delay(1000);
                          mySerial.println("AT");
                          updateSerial();
                          mySerial.println("AT+CMGF=1");
                          updateSerial();
                          mySerial.println("AT+CNMI=1,2,0,0,0");
                          updateSerial();
                          //  pollSms();
                          displayMessage();
                          delay(500);
                          //Start print in led matrix
                          led_module.selectFont(FONT);
                          led_module.drawMarquee(finalMsg, LengMsg, (32 * ROW), 0);
                          long start = millis();
                          long timming = start;
                          boolean flag = false;
                          while (!flag) {
                            if ((timming + 20) < millis()) {
                              flag = led_module.stepMarquee(-1, 0);
                              timming = millis();
                        //------GSM Helper
                        void displayMessage()
                          delay(500);
                          String msg = "";
                          int start = 0, endPoint = 0;
                          finalMsg[100] = "";
                          while (Serial.available())
                            mySerial.write(Serial.read());//Forward what Serial received to Software Serial Port
                            //     parseData(mySerial.readString());//Calls the parseData function to parse SMS
                          while (mySerial.available())
                            msg = mySerial.readString();//Forward what Software Serial received to Serial Port
                          if (msg.length() > 1) {
                            start = msg.indexOf('*') + 1;
                            endPoint = msg.indexOf('#') - 1;
                            int count = 0;
                            if (start > 1 && endPoint > 1) {
                              strcpy( finalMsg, "");
                              for (int i = start; i <= endPoint; i++) {
                                finalMsg[count] = msg[i];
                                count++;
                              Serial.println("SMS Received: ");
                              Serial.println(finalMsg);
                              LengMsg = count;
                            else{
                              return false;
                        void updateSerial()
                          delay(500);
                            Serial.write(mySerial.read());//Forward what Software Serial received to Serial Port
                        NB: The sms body should be between start and hash
                        Eg: * Hello Makers! #
                        C 2 Replies Last reply Reply Quote 0
