    Help needed: Arduino Wireless Notice Board project
    7412
      @rafitc99 , @SAFVAN did you tried the @arunksoman suggestion?
        SAFVAN last edited by
        Now message is displaying with mobile number, date, time.
        I want filter the actual message only.
          salmanfaris @SAFVAN last edited by
          @SAFVAN what was the solution with the previous problem?
          rafitc99 1 Reply Last reply Reply Quote 0
            rafitc99 @salmanfaris last edited by
            @salmanfaris tried @arunksoman suggestion , c_str() instead to_charArray().. But want to parse SMS body only. Now working on that.
            C 1 Reply Last reply Reply Quote 1
              codelery @rafitc99 last edited by
              @rafitc99 what is the final code? Could you please share it with us? I have been battling with a similar project.
              Which Arduino board did you use?
              thanks
                rafitc99 @codelery last edited by
                @codelery You can use any Arduino board. So far as i remember, we used Arduino UNO.
                Somehow i found the code in my gist. It was a 3 year old project. So, i don't remember most of the things
                Code:
                #include <SoftwareSerial.h>
                #include <SPI.h>
                #include <DMD.h>
                #include <TimerOne.h>
                #include "SystemFont5x7.h"
                #include "Arial_black_16.h"
                #define ROW 1
                #define COLUMN 1
                #define FONT Arial_Black_16
                DMD led_module(ROW, COLUMN);
                String st;
                const char *msg;
                unsigned int LengMsg;
                char finalMsg[100] = "";
                SoftwareSerial mySerial(3, 2);
                void scan_module() {
                  led_module.scanDisplayBySPI();
                  Timer1.initialize(2000);
                  Timer1.attachInterrupt(scan_module);
                  led_module.clearScreen( true );
                  mySerial.begin(9600);
                  Serial.println("Starting...");
                  delay(1000);
                  mySerial.println("AT");
                  updateSerial();
                  mySerial.println("AT+CMGF=1");
                  updateSerial();
                  mySerial.println("AT+CNMI=1,2,0,0,0");
                  updateSerial();
                  //  pollSms();
                  displayMessage();
                  delay(500);
                  //Start print in led matrix
                  led_module.selectFont(FONT);
                  led_module.drawMarquee(finalMsg, LengMsg, (32 * ROW), 0);
                  long start = millis();
                  long timming = start;
                  boolean flag = false;
                  while (!flag) {
                    if ((timming + 20) < millis()) {
                      flag = led_module.stepMarquee(-1, 0);
                      timming = millis();
                //------GSM Helper
                void displayMessage()
                  delay(500);
                  String msg = "";
                  int start = 0, endPoint = 0;
                  finalMsg[100] = "";
                  while (Serial.available())
                    mySerial.write(Serial.read());//Forward what Serial received to Software Serial Port
                    //     parseData(mySerial.readString());//Calls the parseData function to parse SMS
                  while (mySerial.available())
                    msg = mySerial.readString();//Forward what Software Serial received to Serial Port
                  if (msg.length() > 1) {
                    start = msg.indexOf('*') + 1;
                    endPoint = msg.indexOf('#') - 1;
                    int count = 0;
                    if (start > 1 && endPoint > 1) {
                      strcpy( finalMsg, "");
                      for (int i = start; i <= endPoint; i++) {
                        finalMsg[count] = msg[i];
                        count++;
                      Serial.println("SMS Received: ");
                      Serial.println(finalMsg);
                      LengMsg = count;
                    else{
                      return false;
                void updateSerial()
                  delay(500);
                    Serial.write(mySerial.read());//Forward what Software Serial received to Serial Port
                NB: The sms body should be between start and hash
                Eg: * Hello Makers! #
                C 2 Replies Last reply Reply Quote 0
                  @rafitc99 thank you so much. I will try it out and see if it will work.
                    This post is deleted!
                      @rafitc99 I tried this code, but the SMS is always corrupted. I got "Hello peopl⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮
                      instead of "Hello people of the village who work day and night to make sure all is well"
                        salmanfaris @codelery last edited by
                        @codelery Could you please share your code for checking?
                        C 1 Reply Last reply Reply Quote 0
