    Help needed: Arduino Wireless Notice Board project
    7412
      salmanfaris @SAFVAN last edited by
      @SAFVAN what was the solution with the previous problem?
      rafitc99 1 Reply Last reply Reply Quote 0
        rafitc99 @salmanfaris last edited by
        @salmanfaris tried @arunksoman suggestion , c_str() instead to_charArray().. But want to parse SMS body only. Now working on that.
        C 1 Reply Last reply Reply Quote 1
          codelery @rafitc99 last edited by
          @rafitc99 what is the final code? Could you please share it with us? I have been battling with a similar project.
          Which Arduino board did you use?
          thanks
            rafitc99 @codelery last edited by
            @codelery You can use any Arduino board. So far as i remember, we used Arduino UNO.
            Somehow i found the code in my gist. It was a 3 year old project. So, i don't remember most of the things
            Code:
            #include <SoftwareSerial.h>
            #include <SPI.h>
            #include <DMD.h>
            #include <TimerOne.h>
            #include "SystemFont5x7.h"
            #include "Arial_black_16.h"
            #define ROW 1
            #define COLUMN 1
            #define FONT Arial_Black_16
            DMD led_module(ROW, COLUMN);
            String st;
            const char *msg;
            unsigned int LengMsg;
            char finalMsg[100] = "";
            SoftwareSerial mySerial(3, 2);
            void scan_module() {
              led_module.scanDisplayBySPI();
              Timer1.initialize(2000);
              Timer1.attachInterrupt(scan_module);
              led_module.clearScreen( true );
              mySerial.begin(9600);
              Serial.println("Starting...");
              delay(1000);
              mySerial.println("AT");
              updateSerial();
              mySerial.println("AT+CMGF=1");
              updateSerial();
              mySerial.println("AT+CNMI=1,2,0,0,0");
              updateSerial();
              //  pollSms();
              displayMessage();
              delay(500);
              //Start print in led matrix
              led_module.selectFont(FONT);
              led_module.drawMarquee(finalMsg, LengMsg, (32 * ROW), 0);
              long start = millis();
              long timming = start;
              boolean flag = false;
              while (!flag) {
                if ((timming + 20) < millis()) {
                  flag = led_module.stepMarquee(-1, 0);
                  timming = millis();
            //------GSM Helper
            void displayMessage()
              delay(500);
              String msg = "";
              int start = 0, endPoint = 0;
              finalMsg[100] = "";
              while (Serial.available())
                mySerial.write(Serial.read());//Forward what Serial received to Software Serial Port
                //     parseData(mySerial.readString());//Calls the parseData function to parse SMS
              while (mySerial.available())
                msg = mySerial.readString();//Forward what Software Serial received to Serial Port
              if (msg.length() > 1) {
                start = msg.indexOf('*') + 1;
                endPoint = msg.indexOf('#') - 1;
                int count = 0;
                if (start > 1 && endPoint > 1) {
                  strcpy( finalMsg, "");
                  for (int i = start; i <= endPoint; i++) {
                    finalMsg[count] = msg[i];
                    count++;
                  Serial.println("SMS Received: ");
                  Serial.println(finalMsg);
                  LengMsg = count;
                else{
                  return false;
            void updateSerial()
              delay(500);
                Serial.write(mySerial.read());//Forward what Software Serial received to Serial Port
            NB: The sms body should be between start and hash
            Eg: * Hello Makers! #
            C 2 Replies Last reply Reply Quote 0
              @rafitc99 thank you so much. I will try it out and see if it will work.
                This post is deleted!
                  @rafitc99 I tried this code, but the SMS is always corrupted. I got "Hello peopl⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮
                  instead of "Hello people of the village who work day and night to make sure all is well"
                    salmanfaris @codelery last edited by
                    @codelery Could you please share your code for checking?
                    C 1 Reply Last reply Reply Quote 0
                      codelery @salmanfaris last edited by codelery
                      @salmanfaris After countless trials and efforts without success, I have decided to use two separate microcontrollers (Atmega328p). One microcontroller receives SMS from SIM800l, parses it and sends it to the second microcontroller via serial interface (Arduino Rx and Tx pin). The second microcontroller receives the message via serial and send it to p10 module for display. This solution is not cost-effective because of the additional microcontroller. However, it solves the problem of interference between DMD library and SoftwareSerial which appeared to be the reason for the corrupted string I shared earlier.
                      However, I am facing another challenge; the message that the second microcontroller receives via serial interface is not complete. When I send "*Hello people of working with you are you doing tonight or tomorrow morning dear#" via SMS, what is received and displayed on p10 is "*Hello people of working with you are you doing tonight or tomo".
                      Here are the two codes:
                      Code for receiving SMS
                       #include <SIM800L.h>
                      SIM800L sim800l(2, 3); //Rx, Tx
                      int LED_PIN = 8;
                      //Enter the phone number of the person whom you want to send sms
                      String reply = "Hey! I have got your message";
                      void handleSMS(String number, String message) {
                        int start_index = message.indexOf('*'); // message starts with '*'
                        int end_index = message.indexOf('#'); // message ends with '*'
                        //message.trim();
                        // if message starts with * and ends with #
                        if(start_index == 0 && end_index == (message.length() - 1)) {
                          Serial.println(message);
                          blinkLed();
                          sim800l.sendSMS(number, reply);
                        pinMode(LED_PIN, OUTPUT);
                        sim800l.begin(9600);
                        sim800l.setSMSCallback(handleSMS);
                        sim800l.listen();
                      void blinkLed(){
                         for(int i = 0; i < 3; i++){
                            digitalWrite(LED_PIN, HIGH);
                            delay(1000);
                            digitalWrite(LED_PIN, LOW);
                            delay(1000);
                      *** Code for receiving and displaying message on p10 ***
                      #include <SPI.h>
                      #include  "buzzer.h"
                      #include <DMD.h>
                      #include "memory.h"
                      #define ROW 3
                      #define COLUMN 1
                      char message [500] = "Welcome to electronic projects workshop 1234";
                      char r_msg[500] = "";
                      bool flag = false;
                      void scan_module()
                      void setup()
                        EEPROM.begin();
                        buzzerSetup();
                        beeps(3);
                        int m_length = EEPROM.read(5);
                          //    strcpy(message, "");
                        String stored_string = read_string(5);
                        char stored_char[stored_string.length() + 1];
                        stored_string.toCharArray(stored_char, stored_string.length() + 1); // convert message from string to array of char
                        strcpy(message, stored_char); // update p10 with stored message
                      void loop()
                        Serial.println(read_string(5));
                          receiveMessage();
                          led_module.drawMarquee(message, strlen(message), (32 * ROW), 0);
                          while (!flag)
                              timming = millis();
                      void receiveMessage()
                          Listens to incoming message through serial interface.
                          It extracts the message if it starts with '*' and ends with '#'
                        while(Serial.available())
                          String s_msg = Serial.readString();
                          // s_msg.trim();
                          int start_index = s_msg.indexOf('*') + 1;
                          int end_index = s_msg.indexOf('#');
                          // whether message contains * and # and also # comes after *
                          if(start_index > 0 ){
                              beeps(1);
                              String substr = s_msg.substring(start_index, end_index - 1);
                              int m_len = substr.length() + 1;
                              char m_msg [m_len];
                              substr.toCharArray(m_msg, m_len);
                              strcpy(message, m_msg);
                              // write to eeprom
                              writeString(5, substr);
                        @codelery It might be because of buffer size of received message. You need to increase the buffer size.
                        Check the section "Expanding Arduino SoftwareSerial Buffer Size" in this tutorial : https://lastminuteengineers.com/sim800l-gsm-module-arduino-tutorial/
                        C 2 Replies Last reply Reply Quote 1
