    Help needed: Arduino Wireless Notice Board project
    7412
      codelery last edited by
      This post is deleted!
        codelery @rafitc99 last edited by
        @rafitc99 I tried this code, but the SMS is always corrupted. I got "Hello peopl⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮
        instead of "Hello people of the village who work day and night to make sure all is well"
          salmanfaris @codelery last edited by
          @codelery Could you please share your code for checking?
          C 1 Reply Last reply Reply Quote 0
            codelery @salmanfaris last edited by codelery
            @salmanfaris After countless trials and efforts without success, I have decided to use two separate microcontrollers (Atmega328p). One microcontroller receives SMS from SIM800l, parses it and sends it to the second microcontroller via serial interface (Arduino Rx and Tx pin). The second microcontroller receives the message via serial and send it to p10 module for display. This solution is not cost-effective because of the additional microcontroller. However, it solves the problem of interference between DMD library and SoftwareSerial which appeared to be the reason for the corrupted string I shared earlier.
            However, I am facing another challenge; the message that the second microcontroller receives via serial interface is not complete. When I send "*Hello people of working with you are you doing tonight or tomorrow morning dear#" via SMS, what is received and displayed on p10 is "*Hello people of working with you are you doing tonight or tomo".
            Here are the two codes:
            Code for receiving SMS
             #include <SIM800L.h>
            SIM800L sim800l(2, 3); //Rx, Tx
            int LED_PIN = 8;
            //Enter the phone number of the person whom you want to send sms
            String reply = "Hey! I have got your message";
            void handleSMS(String number, String message) {
              int start_index = message.indexOf('*'); // message starts with '*'
              int end_index = message.indexOf('#'); // message ends with '*'
              //message.trim();
              // if message starts with * and ends with #
              if(start_index == 0 && end_index == (message.length() - 1)) {
                Serial.println(message);
                blinkLed();
                sim800l.sendSMS(number, reply);
              pinMode(LED_PIN, OUTPUT);
              sim800l.begin(9600);
              sim800l.setSMSCallback(handleSMS);
              sim800l.listen();
            void blinkLed(){
               for(int i = 0; i < 3; i++){
                  digitalWrite(LED_PIN, HIGH);
                  delay(1000);
                  digitalWrite(LED_PIN, LOW);
                  delay(1000);
            *** Code for receiving and displaying message on p10 ***
            #include <SPI.h>
            #include  "buzzer.h"
            #include <DMD.h>
            #include "memory.h"
            #include <TimerOne.h>
            #include "SystemFont5x7.h"
            #include "Arial_black_16.h"
            #define ROW 3
            #define COLUMN 1
            #define FONT Arial_Black_16
            char message [500] = "Welcome to electronic projects workshop 1234";
            char r_msg[500] = "";
            bool flag = false;
            DMD led_module(ROW, COLUMN);
            void scan_module()
              led_module.scanDisplayBySPI();
            void setup()
              EEPROM.begin();
              buzzerSetup();
              beeps(3);
              int m_length = EEPROM.read(5);
                //    strcpy(message, "");
              String stored_string = read_string(5);
              char stored_char[stored_string.length() + 1];
              stored_string.toCharArray(stored_char, stored_string.length() + 1); // convert message from string to array of char
              strcpy(message, stored_char); // update p10 with stored message
              Timer1.initialize(2000);
              Timer1.attachInterrupt(scan_module);
             led_module.clearScreen( true );
            void loop()
              Serial.println(read_string(5));
                receiveMessage();
                led_module.selectFont(FONT);
                led_module.drawMarquee(message, strlen(message), (32 * ROW), 0);
                long start = millis();
                long timming = start;
                boolean flag = false;
                while (!flag)
                  if ((timming + 20) < millis())
                    flag = led_module.stepMarquee(-1, 0);
                    timming = millis();
            void receiveMessage()
                Listens to incoming message through serial interface.
                It extracts the message if it starts with '*' and ends with '#'
              while(Serial.available())
                String s_msg = Serial.readString();
                // s_msg.trim();
                int start_index = s_msg.indexOf('*') + 1;
                int end_index = s_msg.indexOf('#');
                // whether message contains * and # and also # comes after *
                if(start_index > 0 ){
                    beeps(1);
                    String substr = s_msg.substring(start_index, end_index - 1);
                    int m_len = substr.length() + 1;
                    char m_msg [m_len];
                    substr.toCharArray(m_msg, m_len);
                    strcpy(message, m_msg);
                    // write to eeprom
                    writeString(5, substr);
            rafitc99 1 Reply Last reply Reply Quote 0
              rafitc99 @codelery last edited by
              @codelery It might be because of buffer size of received message. You need to increase the buffer size.
              Check the section "Expanding Arduino SoftwareSerial Buffer Size" in this tutorial : https://lastminuteengineers.com/sim800l-gsm-module-arduino-tutorial/
              C 2 Replies Last reply Reply Quote 1
                  @codelery said in Help needed: Arduino Wireless Notice Board project:
                      salmanfaris 1 Reply Last reply Reply Quote 2
                        @codelery Awesome. That's great news. Kudos to @rafitc99 . 🙌
