    how did sudo command solved can't open device "/dev/ttyUSB0": Permission denied?
    arduino linux nodemcu
    2809
    • Abhay
      Abhay last edited by
      Please read full
      This is the most common or the most probable error you might have seen if you tried coding Arduino, nodeMCU etc in Arduino-ide.
      It might happen that when you upload a sketch - after you have selected your board and the serial port -, you get an error Error opening serial port ... If you get this error, we google it and the method to debug it is to set serial port permission.
      this is the steps we followed to solve it. Even though the error stilled showed sometimes and had to use this code again.
      Since I try different distros of Linux sometimes I end up corrupting the old distro and reinstalling it from the beginning.
      This time I actually didn't follow these step but installed Arduino from the terminal using sudo apt install arduino command and run the code. The interface was completely different. The image below is the general interface of ide but installing it with sudo command give an ide with same screen but no setup{} or loop() part, a blank screen.
      An error popped up about the port issue and solution to add the user to the group was mentioned in the terminal and followed the same command. After which the error never showed. I also snap installed arduino.
      Now my question is : By installing arduino using sudo command did I install ide or supporting libraries and why did the error stop?
        arunksoman last edited by arunksoman
        1. Go to Arduino software
        2. Download Linnux 64-bit or 32-bit software
        3. Extract the Downloaded tar.xz file on your home directory.
        4. Navigate to your extracted file using cd command:
          cd arduino-1.8.12-linux64
        5. Make the install.sh file executable:
          sudo chmod +x install.sh
        6. Install arduino using shell script
          sudo ./install.sh
        7. Open Terminal and type:
          ls -l /dev/ttyACM*
          you will get something like:
          crw-rw---- 1 root dialout 188, 0 5 apr 23.01 ttyACM0
          The "0" at the end of ACM might be a different number, or multiple entries might be returned. The data we need is "dialout" (is the group owner of the file).
          Now we just need to add our user to the group:
          sudo usermod -a -G dialout <username>
        I believes it is a better way to solve your problem. Other way you to try to solve problem is install arduino via:
        sudo apt-get install arduino-core
        Abhay 1 Reply Last reply Reply Quote 2
        • Abhay
          Abhay @arunksoman last edited by
          @arunksoman thanks for the steps
          but the thing is I don't have issues with port now, I was curious how it got resolved without going through the usual steps but by using sudo command.
            arunksoman @Abhay last edited by arunksoman
            @Abhay What did you mean by usual steps?
            Abhay 1 Reply Last reply Reply Quote 0
            • Abhay
              @arunksoman by usual steps I meant adding our user to the group.
              ie the step
                @Abhay I think most probably you might have done this earlier while installing Arduino.
                • Abhay
                  @arunksoman thanks,
                  I will look more into it. Thanks again
                  • Facility Management Software is designed to help organizations efficiently manage buildings, assets, and daily operations from a centralized platform. It enables teams to automate maintenance activities, track assets in real time, manage work orders, and schedule preventive maintenance to reduce downtime and operational costs. With integrated tools for space management, inventory control, vendor coordination, and compliance tracking, the software ensures smooth and uninterrupted facility operations.
                    By providing real-time data and performance insights, Facility Management Software supports informed decision-making and improves resource utilization. It enhances productivity, extends asset lifespan, and ensures safety and regulatory compliance across facilities. Suitable for industries such as manufacturing, healthcare, IT, hospitality, education, and commercial real estate, the solution simplifies complex facility workflows and helps organizations achieve operational efficiency, sustainability, and long-term cost control.
                    Mumbai Escorts
                    Mira Road Escorts
                    Udaipur Escorts
                    Rajkot Escorts
                    Bhubaneswar Escorts
                    Andheri Escorts
                    Ahmedabad Escorts
                    Nariman Point Escorts
                    Bandra Escorts
                    Airoli Escorts
                    Ambernath Escorts
                    Badlapur Escorts
                    Belapur Escorts
                    Bhandup Escorts
                    Bhayandar Escorts
                    Borivali Escorts
                    Chembur Escorts
                    Colaba Escorts
                    Cotton Green Escorts
                    Dadar Escorts
                    Dahisar Escorts
                    Diva Escorts
                    Dombivali Escorts
                    Ghansoli Escorts
                    Goddbonder Road Escorts
                    Goregaon Escorts
                    Govandi Escorts
                    Gtb Nagar Escorts
                    Indore Escorts
                    Juhu Escorts
                    Kalamboli Escorts
                    Kalwa Escorts
                    Kalyan Escorts
                    Kashimira Escorts
                    Kopar Khairane Escorts
                    Kurla Escorts
                    Lokhandwala Escorts
                    Malad Escorts
                    Mankhurd Escorts
                    Masjid Bunder Escorts
                    Mulund Escorts
                    Mumbra Escorts
                    Nahur Escorts
                    Navi Mumbai Escorts
                    Nerul Escorts
                    Panve Escortsl Escorts
                    Powai Escorts
                    Rabale Escorts
                    Sanpada Escorts
                    Santa Cruz Escorts
                    Seawood Escorts
                    Taloja Escorts
                    Thane Escorts
                    Tilak Nagar Escorts
                    Turbhe Escorts
                    Ulhasnagar Escorts
                    Vartak Nagar Escorts
                    Vashi Escorts
                    Vikhroli Escorts
                    Vile Parle Escorts
                    Wadala Road Escorts
                    Bangalore Escorts
                    Delhi Escorts
                    Gurgaon Escorts
                    Hyderabad Escorts
                    Jaipur Escorts
                    Kolkata Escorts
                    Lucknow Escorts
                    Noida Escorts
                    Patna Escorts
                    Pune Escorts
                    Ranchi Escorts
                    Surat Escorts
                    Bhopal Escorts
                    Ghaziabad Escorts
                    Allahabad Escorts
                    Mumbai Escorts
                    Mount Abu Escorts
                    Indore Escorts
                    Udaipur Escorts
                    Mumbai Call Girls
                    Mumbai Call Girls
                    Call Girls in Mumbai
                    Pune Escorts
                    Hyderabad Escorts
                    Andheri Escorts
                    Andheri Escorts
                    Chennai Escorts
                    Mumbai Escorts
                    Jalandha Escorts
                    Jamshedpur Escorts
                    Varanasi Escorts
                    Rishikesh Escorts
                    Zirakpur Escorts
                    Vadodara Escorts
                    Mount Abu Escorts
                    Ajmer Escorts
                    Dehradun Escorts
                    Manali Escorts
                    Jammu Escorts
                    Haridwar Escorts
                    Kochi Escorts
                    Vijayawada Escorts
                    Visakhapatnam Escorts
                    Mathura Escorts
                    Raipur Escorts
                    Daman Escorts
                    Shimla Escorts
                    Agra Escorts
                    Indore Escorts
                    Indore Escorts
                    Chennai Escorts
                    Indore Escorts
                    Ujjain Escorts
                    Badnawar Escorts
                    Badnagar Escorts
                    Shajapur Escorts
                    Dewas Escorts
                    Nagda Escorts
                    Ratlam Escorts
                    Sillod Escorts
                    Jalgaon Escorts
                    Bhusawal Escorts
                    Amalner Escorts
                    Ahmednagar Escorts
                    Dhule Escorts
                    Jalna Escorts
                    Udaipur Escorts
                    Kutch Escorts
                    Somnath Escorts
                    Porbandar Escorts
                    Aurangabad Escorts
                    Sabarmati Escorts
                    Cg Road Escorts
                    Vastrapur Escorts
                    Naroda Escorts
                    Narol Escorts
                    Sg Highway Escorts
                    Gota Escorts
                    Chandkheda Escorts
                    Ambawadi Escorts
                    Asarwa Escorts
                    Ashram Road Escorts
                    Satellite Escorts
                    Sarkhej Escorts
                    Paldi Escorts
                    Sola Escorts
                    Ranip Escorts
                    Shahpur Escorts
                    Thaltej Escorts
                    Vasna Escorts
                    Maninagar Escorts
                    Chopda Escorts
                    Chennai Escorts
                    Jalandhar Escorts
                    Jammu Escorts
                    Jhansi Escorts
                    Karnal Escorts
                    Kota Escorts
                    Kullu Escorts
                    Laddakh Escorts
                    Leh Escorts
                    Manipur Escorts
                    Meerut Escorts
                    Meghalaya Escorts
                    Mount Abu Escorts
                    Muzaffarnagar Escorts
                    Mysore Escorts
                    Nagpur Escorts
                    Nainital Escorts
                    Nashik Escorts
                    Navi Mumbai Escorts
                    Ooty Escorts
                    Pathankot Escorts
                    Pondicherry Escorts
                    Shimla Escorts
                    Sikkim Escorts
                    Siliguri Escorts
                    Champaner Escorts
                    Veraval Escorts
                    Surat Escorts
                    Vadodara Escorts
                    Ahmedabad Escorts
                    Agra Escorts
                    Dehradun Escorts
                    Gurgaon Escorts
                    Hyderabad Escorts
                    Jaipur Escorts
                    Jodhpur Escorts
                    Kanpur Escorts
                    Kolkata Escorts
                    Lucknow Escorts
                    Goa Escorts
                    Mumbai Escorts
                    Mussoorie Escorts
                    Raipur Escorts
                    Delhi Escorts
                    Ranchi Escorts
                    Rishikesh Escorts
                    Ajmer Escorts
                    Allahabad Escorts
                    Almora Escorts
                    Alwar Escorts
                    Ambala Escorts
                    Amravati Escorts
                    Bareilly Escorts
                    Bathinda Escorts
                    Bhilai Escorts
                    Bhopal Escorts
                    Bbhubaneswar Escorts
                    Bikaner Escorts
                    Bilaspur Escorts
                    Coimbatore Escorts
                    Chandigarh Escorts
                    Daman Escorts
                    Darjeeling Escorts
                    Gangtok Escorts
                    Gorakhpur Escorts
                    Noida Escorts
                    Guwahati Escorts
                    Haldwani Escorts
                    Hapur Escorts
                    Imphal Escorts
                    Jabalpur Escorts
                    Jaisalmer Escorts
                    Anand Escorts
                    Gandhidham Escorts
                    Mehsana Escorts
                    Morbi Escorts
                    Palitana Escorts
                    Ambaji Escorts
                    Vapi Escorts
                    Ankleshwar Escorts
                    Adalaj Escorts
                    Dahod Escorts
                    Amreli Escorts
                    Dakor Escorts
                    Botad Escorts
                    Kandla Escorts
                    Diu Escorts
                    Mandvi Escorts
                    Anjar Escorts
                    Himmatnagar Escorts
                    Panchmahal Escorts
                    Sonipat Escorts
                    Srinagar Escorts
                    Tirupati Escorts
                    Tripura Escorts
                    Varanasi Escorts
                    Zirakpur Escorts
                    Kochi Escorts
                    Airoli Escorts
                    Andheri Escorts
                    Bandra Escorts
                    Belapur Escorts
                    Borivali Escorts
                    Chembur Escorts
                    Colaba Escorts
                    Dadar Escorts
                    Dahisar Escorts
                    Dharavi Escorts
                    Ghatkopar Escorts
                    Goregaon Escorts
                    Grant Road Escorts
                    Gondal Escorts
                    Navsari Escorts
                    Palanpur Escorts
                    Valsad Escorts
                    Nadiad Escorts
                    Godhra Escorts
                    Saputara Escorts
                    Juhu Escorts
                    Kandivali Escorts
                    Khar Escorts
                    Kharghar Escorts
                    Kurla Escorts
                    Lokhandwala Escorts
                    Mahim Escorts
                    Malad Escorts
                    Marine Drive Escorts
                    Mira Road Escorts
                    Mulund Escorts
                    Nerulpanvel Escorts
                    Powai Escorts
                    Sakinaka Escorts
                    Santacruz Escorts
                    Seawood Escorts
                    Vasai Escorts
                    Vashi Escorts
                    Vileparle Escorts
                    Wadala Escorts
                    Worli Escorts
                    Rajkot Escorts
                    Junagadh Escorts
                    Jamnagar Escorts
                    Bhavnagar Escorts
                    Gandhinagar Escorts
                    Bhuj Escorts
                    Bharuch Escorts
                    Bangalore Escorts
