    [Solved] Help needed for face detection -deep learning
    3141
      Happy to know that 😊 , thanks to @arunksoman 🤝 , Happy Making 💥
        arunksoman @Nandu last edited by
        @Nandu You are still confusing me because your title saying you have to count faces, your picture shows, counting of cars🤔. Actually what are you trying to make?
        Nandu 1 Reply Last reply Reply Quote 0
        • Nandu
          Nandu @arunksoman last edited by
          @arunksoman yes.In my project ,subject is car.So if i get some idea regarding counting faces then i could modify it.In my project i don't want to copy anyone's code,for getting some idea i have asked you.
          A 1 Reply Last reply Reply Quote 0
            @Nandu Are you using your own haarcascade? If not try to make your own one car.xml. It will be a nice experience. One more doubt, why are you not detecting other vehicles rather than car?
            Mennyt 1 Reply Last reply Reply Quote 0
            • Mennyt
              Mennyt @arunksoman last edited by
              @arunksoman how do we make the cars.xml file???
                arunksoman @Mennyt last edited by arunksoman
                @Mennyt Hai Mennyt. There is a couple of ways:
                1. Using Cascade Trainer GUI- Tutorial
                2. Programmatic way
