    [Solved] Help needed for face detection -deep learning
    3376
      @Nandu Did you complete? excited to see.
      Nandu 1 Reply Last reply Reply Quote 0
      • Nandu
        Nandu @salmanfaris last edited by salmanfaris
        @salmanfaris in the below terminal count shows.some steps i have followed in a different manner.Thank you for helping me!๐Ÿ™‚
        A 1 Reply Last reply Reply Quote 1
          Happy to know that ๐Ÿ˜Š , thanks to @arunksoman ๐Ÿค , Happy Making ๐Ÿ’ฅ
            arunksoman @Nandu last edited by
            @Nandu You are still confusing me because your title saying you have to count faces, your picture shows, counting of cars๐Ÿค”. Actually what are you trying to make?
            • Nandu
              Nandu @arunksoman last edited by
              @arunksoman yes.In my project ,subject is car.So if i get some idea regarding counting faces then i could modify it.In my project i don't want to copy anyone's code,for getting some idea i have asked you.
                @Nandu Are you using your own haarcascade? If not try to make your own one car.xml. It will be a nice experience. One more doubt, why are you not detecting other vehicles rather than car?
                Mennyt 1 Reply Last reply Reply Quote 0
                • Mennyt
                  Mennyt @arunksoman last edited by
                  @arunksoman how do we make the cars.xml file???
                    arunksoman @Mennyt last edited by arunksoman
                    @Mennyt Hai Mennyt. There is a couple of ways:
                    1. Using Cascade Trainer GUI- Tutorial
                    2. Programmatic way
                      Hello everyone! Weโ€™re planning on organizing a two-phase event that explores device-to-device communication using ESP-NOW protocol :
                      Weโ€™d love your suggestions on ways to simplify hardware, reducing the cost, secure partnerships and funding, or enhance the interactive elements. Thank you, looking forward to any ideas that can help make the event engaging and successful!
                      Can you share the GPS and LoRa output when itโ€™s working?
