    [Solved] leaf disease detection using keras
    5308
      sreu13 last edited by
      @salmanfaris said in leaf disease detection using keras:
      pip install scikit-learn==0.15.2
      tried downgrading, but came up with this error.
      ERROR: Failed building wheel for scikit-learn
      and I've been following Kaggle kernel,
      link-https://www.kaggle.com/emmarex/plant-disease-detection-using-keras
        SuperGops last edited by
        I think you need to use the fit or fit_transform function before you predict the classes and use the Binarizer. Have a look at scikit's official documentation for the same.
        https://scikit-learn.org/stable/modules/generated/sklearn.preprocessing.LabelBinarizer.html
          sreu13 @SuperGops last edited by
          @SuperGops
          i've entered this code,
          def fit_transform(self, n_classes):
          but as I run it, I get the indentation Error given below
          File"C:/Users/admin/Desktop/plant_disease_classification/plant_disease_classification/untitled1.py", line 42
          label_binarizer = LabelBinarizer()
          IndentationError: expected an indented block
            SuperGops @sreu13 last edited by
            @sreu13
            fit and fit_transform are actually inbuilt functions found in the scikit-learn library. So I'd suggest you fit your model with the available data using those functions whose application can be found on scikit-learn's documentation and then proceed with the Binarizer.
              @SuperGops
              so basically ,i'll have to restart and retrain the model with fit_transform?
                @sreu13 Yup
                  Could you please follow my steps:
                  1. Uninstall your current Python 3.7 version
                  2. Install Python 3.6.5
                  3. If you are using spyder editor make a change to vscode.
                  4. Go to integrated terminal of vscode and create a virtual environment
                  python -m venv venv
                  1. Activate your virtual environment
                  .\venv\Scripts\activate
                  1. Create a requirements.txt over your current working directory. Contents for requirements.txt given below:
                  h5py==2.8.0
                  imutils==0.5.1
                  Keras==2.2.4
                  Keras-Applications==1.0.6
                  Keras-Preprocessing==1.0.5
                  kiwisolver==1.0.1
                  matplotlib==3.0.2
                  numpy==1.15.3
                  opencv-contrib-python==3.4.3.18
                  Pillow==5.3.0
                  PyWavelets==1.0.1
                  scikit-image==0.14.1
                  scikit-learn==0.20.0
                  scipy==1.1.0
                  six==1.11.0
                  sklearn==0.0
                  tensorboard==1.12.0
                  tensorflow==1.12.0
                  termcolor==1.1.0
                  toolz==0.9.0
                  1. Then install necessary packages using requirements.txt file
                  pip install -r requirements.txt
                  1. Then run your code within this venv and say what happened as reply here.
                  S 2 Replies Last reply Reply Quote 0
                    @SuperGops
                    i also have another pickle file "label_transform", which I got as an output from referring the initial code from gaggle, is there any use of this file?
                    image_labels = label_binarizer.fit_transform(label_list)
                    pickle.dump(label_binarizer,open('label_transform.pkl', 'wb'))
                    n_classes = len(label_binarizer.classes_)
                    Kaggle >https://www.kaggle.com/emmarex/plant-disease-detection-using-keras/data
                      sreu13 @arunksoman last edited by
                      @arunksoman
                      i'll follow this proceedure, but would I be able to deploy this code in raspberry pi 4?
                        arunksoman @sreu13 last edited by
                        @sreu13 As the @SuperGops says you have to use fit_transform. It can be implemented on Raspberry Pi 4. But if it slows down your pi you have use multiprocessing as well as threads to improve that.
                        • MatjarX is a results-driven web development company in Karachi focused on helping small businesses get online quickly and affordably. We specialize in done-for-you websites built in just 7 days, combining strategic design, technical development, SEO services, website concierge assistance, and growth marketing under one roof. Our team of global professionals works closely with clients to remove the stress of launching and managing a website, ensuring every business has the tools, visibility, and ongoing support needed to grow confidently in the digital world.
