    [Solved] leaf disease detection using keras
    5109
      sreu13 last edited by salmanfaris
      The code given below is for image classification, it seems to be running well until the last iteration which gives the following error >
      "C:/Users/admin/Desktop/plant_disease_classification/plant_disease_classification/untitled1.py", line 45, in <module>
      print (label_binarizer.classes_[predict1])
      AttributeError: 'LabelBinarizer' object has no attribute 'classes_'
      import numpy as np
      import pickle
      import cv2
      from os import listdir
      from sklearn.preprocessing import LabelBinarizer
      from keras.models import load_model
      from keras.models import Sequential
      from keras.preprocessing import image
      from keras.preprocessing.image import img_to_array
      from sklearn.preprocessing import MultiLabelBinarizer
      from sklearn.model_selection import train_test_split
      import matplotlib.pyplot as plt
      import tensorflow
      default_image_size = tuple((256, 256))
      #load the pickle file
      file_object = open(r'C:\Users\admin\Desktop\pr3\cnn_model.pkl', 'rb')
      model = pickle.load(file_object)
      #load the leaf image that is to be classified
      imgpath=r'C:\Users\admin\Desktop\pr1\PlantVillage\diseases\Pepper__bell___healthy\0a3f2927-4410-46a3-bfda-5f4769a5aaf8___JR_HL 8275.JPG'
      def convert_image_to_array(image_dir):
          try:
              image = cv2.imread(image_dir)
              if image is not None :
                  image = cv2.resize(image, default_image_size)
                  return img_to_array(image)
              else :
                  return np.array([])
          except Exception as e:
              print(f"Error : {e}")
              return None
      imar = convert_image_to_array(imgpath)
      np_image_list = np.array([imar], dtype=np.float16) / 225.0
      label_binarizer = LabelBinarizer()
      predict1 = model.predict(np_image_list)
      the screenshot of the above complied code and error is uploaded for reference.
        @sreu13 said in leaf disease detection using keras:
        Hi, Can you try downgrade the scikit by typing
        pip install scikit-learn==0.15.2
        and are you following any guide or something, if yes can you share that also?
          @salmanfaris said in leaf disease detection using keras:
          tried downgrading, but came up with this error.
          ERROR: Failed building wheel for scikit-learn
          and I've been following Kaggle kernel,
          link-https://www.kaggle.com/emmarex/plant-disease-detection-using-keras
            SuperGops last edited by
            I think you need to use the fit or fit_transform function before you predict the classes and use the Binarizer. Have a look at scikit's official documentation for the same.
            https://scikit-learn.org/stable/modules/generated/sklearn.preprocessing.LabelBinarizer.html
              sreu13 @SuperGops last edited by
              @SuperGops
              i've entered this code,
              def fit_transform(self, n_classes):
              but as I run it, I get the indentation Error given below
              File"C:/Users/admin/Desktop/plant_disease_classification/plant_disease_classification/untitled1.py", line 42
              IndentationError: expected an indented block
                SuperGops @sreu13 last edited by
                @sreu13
                fit and fit_transform are actually inbuilt functions found in the scikit-learn library. So I'd suggest you fit your model with the available data using those functions whose application can be found on scikit-learn's documentation and then proceed with the Binarizer.
                  @SuperGops
                  so basically ,i'll have to restart and retrain the model with fit_transform?
                    @sreu13 Yup
                      Could you please follow my steps:
                      1. Uninstall your current Python 3.7 version
                      2. Install Python 3.6.5
                      3. If you are using spyder editor make a change to vscode.
                      4. Go to integrated terminal of vscode and create a virtual environment
                      python -m venv venv
                      1. Activate your virtual environment
                      .\venv\Scripts\activate
                      1. Create a requirements.txt over your current working directory. Contents for requirements.txt given below:
                      h5py==2.8.0
                      imutils==0.5.1
                      Keras==2.2.4
                      Keras-Applications==1.0.6
                      Keras-Preprocessing==1.0.5
                      kiwisolver==1.0.1
                      matplotlib==3.0.2
                      numpy==1.15.3
                      opencv-contrib-python==3.4.3.18
                      Pillow==5.3.0
                      PyWavelets==1.0.1
                      scikit-image==0.14.1
                      scikit-learn==0.20.0
                      scipy==1.1.0
                      six==1.11.0
                      sklearn==0.0
                      tensorboard==1.12.0
                      tensorflow==1.12.0
                      termcolor==1.1.0
                      toolz==0.9.0
                      1. Then install necessary packages using requirements.txt file
                      pip install -r requirements.txt
                      1. Then run your code within this venv and say what happened as reply here.
                      S 2 Replies Last reply Reply Quote 0
                        @SuperGops
                        i also have another pickle file "label_transform", which I got as an output from referring the initial code from gaggle, is there any use of this file?
                        image_labels = label_binarizer.fit_transform(label_list)
                        pickle.dump(label_binarizer,open('label_transform.pkl', 'wb'))
                        n_classes = len(label_binarizer.classes_)
                        Kaggle >https://www.kaggle.com/emmarex/plant-disease-detection-using-keras/data
