    Gps data is not getting into TTN console after Connecting LoRa E5
    • zainmuhammed
      zainmuhammed last edited by
      I'm working on building a tracker with Xiao nrf52840 sense, Lora E5 and with NEO M8N GPS module.
      Now I have completed connecting XIAO nRF SENSE, LoRa E5 with TTN and it is working properly . Also I connect GPS to Pin number 4 and 5 using SS and it's working properly.
      Now both GPS and LoRa individually working properly. When I combine both GPS and LoRa, Lora in hardware serial and gps in software serial LoRa is connecting to the ttn and sending 0, 0 as latitude and longitude. And also I give a separate power for GPS.
      anyone can help me to fix the issue
      zainmuhammed 1 Reply Last reply Reply Quote 0
      • zainmuhammed
        zainmuhammed @zainmuhammed last edited by
        @zainmuhammed
        this is the code
        #include <Arduino.h>
        #include <U8x8lib.h>
        #include <TinyGPS++.h>
        #include <SoftwareSerial.h>
        static const int RXPin = 1, TXPin = 2;
        static const uint32_t GPSBaud = 9600;
        // The TinyGPS++ object
        TinyGPSPlus gps;
        // The serial connection to the GPS device
        SoftwareSerial ss(RXPin, TXPin);
        U8X8_SSD1306_128X64_NONAME_HW_I2C u8x8(/*reset=*/U8X8_PIN_NONE);
        // U8X8_SSD1306_128X64_NONAME_SW_I2C u8x8(/*clock=*/ SCL, /*data=*/ SDA, /*reset=*/ U8X8_PIN_NONE);   // OLEDs without Reset of the Display
        static char recv_buf[512];
        static bool is_exist = false;
        static bool is_join = false;
        static int led = 0;
        static int at_send_check_response(char *p_ack, int timeout_ms, char *p_cmd, ...) {
          int ch;
          int num = 0;
          int index = 0;
          int startMillis = 0;
          va_list args;
          char cmd_buffer[256];  // Adjust the buffer size as needed
          memset(recv_buf, 0, sizeof(recv_buf));
          va_start(args, p_cmd);
          vsprintf(cmd_buffer, p_cmd, args);  // Format the command string
          Serial1.print(cmd_buffer);
          Serial.print(cmd_buffer);
          va_end(args);
          delay(200);
          startMillis = millis();
          if (p_ack == NULL) {
            return 0;
          do {
            while (Serial1.available() > 0) {
              ch = Serial1.read();
              recv_buf[index++] = ch;
              Serial.print((char)ch);
              delay(2);
            if (strstr(recv_buf, p_ack) != NULL) {
              return 1;
          } while (millis() - startMillis < timeout_ms);
          return 0;
        static void recv_prase(char *p_msg) {
          if (p_msg == NULL) {
            return;
          char *p_start = NULL;
          int data = 0;
          int rssi = 0;
          int snr = 0;
          p_start = strstr(p_msg, "RX");
          if (p_start && (1 == sscanf(p_start, "RX: \"%d\"\r\n", &data))) {
            Serial.println(data);
            u8x8.setCursor(2, 4);
            u8x8.print("led :");
            led = !!data;
            u8x8.print(led);
            if (led) {
              digitalWrite(LED_BUILTIN, LOW);
            } else {
              digitalWrite(LED_BUILTIN, HIGH);
          p_start = strstr(p_msg, "RSSI");
          if (p_start && (1 == sscanf(p_start, "RSSI %d,", &rssi))) {
            u8x8.setCursor(0, 6);
            u8x8.print("                ");
            u8x8.setCursor(2, 6);
            u8x8.print("rssi:");
            u8x8.print(rssi);
          p_start = strstr(p_msg, "SNR");
          if (p_start && (1 == sscanf(p_start, "SNR %d", &snr))) {
            u8x8.setCursor(0, 7);
            u8x8.print("                ");
            u8x8.setCursor(2, 7);
            u8x8.print("snr :");
            u8x8.print(snr);
        void setup(void) {
          u8x8.begin();
          u8x8.setFlipMode(1);
          u8x8.setFont(u8x8_font_chroma48medium8_r);
          ss.begin(GPSBaud);
          Serial.begin(GPSBaud);
          pinMode(LED_BUILTIN, OUTPUT);
          Serial1.begin(9600);
          Serial.print("E5 LORAWAN TEST\r\n");
          u8x8.setCursor(0, 0);
          if (at_send_check_response("+AT: OK", 100, "AT\r\n")) {
            is_exist = true;
            at_send_check_response("+ID: DevEui", 1000, "AT+ID=DevEui,\"xxxxx\"\r\n"); // replace 'xxxxxxxxxxxxx' with your DevEui
            at_send_check_response("+ID: AppEui", 1000, "AT+ID=AppEui,\"xxxxxxx\"\r\n"); // replace 'xxxxxxxxxxxxx' with your AppEui
            at_send_check_response("+KEY: APPKEY", 1000, "AT+KEY=APPKEY,\"xxxxxxxxx\"\r\n"); // replace 'xxxxxxxxxxxxx' with your AppKey
            at_send_check_response("+ID: DevAddr", 1000, "AT+ID=DevAddr\r\n");
            at_send_check_response("+ID: AppEui", 1000, "AT+ID\r\n");
            at_send_check_response("+MODE: LWOTAA", 1000, "AT+MODE=LWOTAA\r\n");
            at_send_check_response("+DR: IN865", 1000, "AT+DR=IN865\r\n");  // Change FREQ as per your location
            at_send_check_response("+CH: NUM", 1000, "AT+CH=NUM,0-2\r\n");
            at_send_check_response("+CLASS: C", 1000, "AT+CLASS=A\r\n");
            at_send_check_response("+PORT: 8", 1000, "AT+PORT=8\r\n");
            delay(200);
            u8x8.setCursor(5, 0);
            u8x8.print("LoRaWAN");
            is_join = true;
          } else {
            is_exist = false;
            Serial.print("No E5 module found.\r\n");
            u8x8.setCursor(0, 1);
            u8x8.print("unfound E5 !");
          u8x8.print(led);
        void loop(void) {
          if (is_exist) {
            int ret = 0;
            if (is_join) {
              ret = at_send_check_response("+JOIN: Network joined", 12000, "AT+JOIN\r\n");
              if (ret) {
                is_join = false;
              } else {
                Serial.print("JOIN failed!\r\n\r\n");
                delay(5000);
            } else {
              gps.encode(ss.read());
              float a=gps.location.lat();
              float b=gps.location.lng();
              Serial.println(a);
              Serial.println(b);
              char cmd[128];
              sprintf(cmd, "AT+CMSGHEX=\"%04X%04X\"\r\n", (float)a,(float)b);
              ret = at_send_check_response("Done", 5000, cmd);
              if (ret) {
                recv_prase(recv_buf);
              } else {
                Serial.print("Send failed!\r\n\r\n");
              delay(5000);
          } else {
            delay(1000);
          salmanfaris @zainmuhammed last edited by
          Hi @zainmuhammed ,
          • zainmuhammed
            zainmuhammed @salmanfaris last edited by
            @salmanfaris Today I tried after connecting a 18650 cell,
              salmanfaris @zainmuhammed last edited by salmanfaris
              @zainmuhammed Can try capturing the GPS when the device is starting the loop instead after joining the LoRaWAN and see?
