    Gps data is not getting into TTN console after Connecting LoRa E5
    • zainmuhammed
      zainmuhammed last edited by
      I'm working on building a tracker with Xiao nrf52840 sense, Lora E5 and with NEO M8N GPS module.
      Now I have completed connecting XIAO nRF SENSE, LoRa E5 with TTN and it is working properly . Also I connect GPS to Pin number 4 and 5 using SS and it's working properly.
      Now both GPS and LoRa individually working properly. When I combine both GPS and LoRa, Lora in hardware serial and gps in software serial LoRa is connecting to the ttn and sending 0, 0 as latitude and longitude. And also I give a separate power for GPS.
      anyone can help me to fix the issue
      zainmuhammed 1 Reply Last reply Reply Quote 0
      • zainmuhammed
        zainmuhammed @zainmuhammed last edited by
        @zainmuhammed
        this is the code
        #include <Arduino.h>
        #include <U8x8lib.h>
        #include <TinyGPS++.h>
        #include <SoftwareSerial.h>
        static const int RXPin = 1, TXPin = 2;
        static const uint32_t GPSBaud = 9600;
        // The TinyGPS++ object
        TinyGPSPlus gps;
        // The serial connection to the GPS device
        SoftwareSerial ss(RXPin, TXPin);
        U8X8_SSD1306_128X64_NONAME_HW_I2C u8x8(/*reset=*/U8X8_PIN_NONE);
        // U8X8_SSD1306_128X64_NONAME_SW_I2C u8x8(/*clock=*/ SCL, /*data=*/ SDA, /*reset=*/ U8X8_PIN_NONE);   // OLEDs without Reset of the Display
        static char recv_buf[512];
        static bool is_exist = false;
        static bool is_join = false;
        static int led = 0;
        static int at_send_check_response(char *p_ack, int timeout_ms, char *p_cmd, ...) {
          int ch;
          int num = 0;
          int index = 0;
          int startMillis = 0;
          va_list args;
          char cmd_buffer[256];  // Adjust the buffer size as needed
          memset(recv_buf, 0, sizeof(recv_buf));
          va_start(args, p_cmd);
          vsprintf(cmd_buffer, p_cmd, args);  // Format the command string
          Serial1.print(cmd_buffer);
          Serial.print(cmd_buffer);
          va_end(args);
          delay(200);
          startMillis = millis();
          if (p_ack == NULL) {
            return 0;
          do {
            while (Serial1.available() > 0) {
              ch = Serial1.read();
              recv_buf[index++] = ch;
              Serial.print((char)ch);
              delay(2);
            if (strstr(recv_buf, p_ack) != NULL) {
              return 1;
          } while (millis() - startMillis < timeout_ms);
          return 0;
        static void recv_prase(char *p_msg) {
          if (p_msg == NULL) {
            return;
          char *p_start = NULL;
          int data = 0;
          int rssi = 0;
          int snr = 0;
          p_start = strstr(p_msg, "RX");
          if (p_start && (1 == sscanf(p_start, "RX: \"%d\"\r\n", &data))) {
            Serial.println(data);
            u8x8.setCursor(2, 4);
            u8x8.print("led :");
            led = !!data;
            u8x8.print(led);
            if (led) {
              digitalWrite(LED_BUILTIN, LOW);
            } else {
              digitalWrite(LED_BUILTIN, HIGH);
          p_start = strstr(p_msg, "RSSI");
          if (p_start && (1 == sscanf(p_start, "RSSI %d,", &rssi))) {
            u8x8.setCursor(0, 6);
            u8x8.print("                ");
            u8x8.setCursor(2, 6);
            u8x8.print("rssi:");
            u8x8.print(rssi);
          p_start = strstr(p_msg, "SNR");
          if (p_start && (1 == sscanf(p_start, "SNR %d", &snr))) {
            u8x8.setCursor(0, 7);
            u8x8.print("                ");
            u8x8.setCursor(2, 7);
            u8x8.print("snr :");
            u8x8.print(snr);
        void setup(void) {
          u8x8.begin();
          u8x8.setFlipMode(1);
          u8x8.setFont(u8x8_font_chroma48medium8_r);
          ss.begin(GPSBaud);
          Serial.begin(GPSBaud);
          pinMode(LED_BUILTIN, OUTPUT);
          Serial1.begin(9600);
          Serial.print("E5 LORAWAN TEST\r\n");
          u8x8.setCursor(0, 0);
          if (at_send_check_response("+AT: OK", 100, "AT\r\n")) {
            is_exist = true;
            at_send_check_response("+ID: DevEui", 1000, "AT+ID=DevEui,\"xxxxx\"\r\n"); // replace 'xxxxxxxxxxxxx' with your DevEui
            at_send_check_response("+ID: AppEui", 1000, "AT+ID=AppEui,\"xxxxxxx\"\r\n"); // replace 'xxxxxxxxxxxxx' with your AppEui
            at_send_check_response("+KEY: APPKEY", 1000, "AT+KEY=APPKEY,\"xxxxxxxxx\"\r\n"); // replace 'xxxxxxxxxxxxx' with your AppKey
            at_send_check_response("+ID: DevAddr", 1000, "AT+ID=DevAddr\r\n");
            at_send_check_response("+ID: AppEui", 1000, "AT+ID\r\n");
            at_send_check_response("+MODE: LWOTAA", 1000, "AT+MODE=LWOTAA\r\n");
            at_send_check_response("+DR: IN865", 1000, "AT+DR=IN865\r\n");  // Change FREQ as per your location
            at_send_check_response("+CH: NUM", 1000, "AT+CH=NUM,0-2\r\n");
            at_send_check_response("+CLASS: C", 1000, "AT+CLASS=A\r\n");
            at_send_check_response("+PORT: 8", 1000, "AT+PORT=8\r\n");
            delay(200);
            u8x8.setCursor(5, 0);
            u8x8.print("LoRaWAN");
            is_join = true;
          } else {
            is_exist = false;
            Serial.print("No E5 module found.\r\n");
            u8x8.setCursor(0, 1);
            u8x8.print("unfound E5 !");
          u8x8.print(led);
        void loop(void) {
          if (is_exist) {
            int ret = 0;
            if (is_join) {
              ret = at_send_check_response("+JOIN: Network joined", 12000, "AT+JOIN\r\n");
              if (ret) {
                is_join = false;
              } else {
                Serial.print("JOIN failed!\r\n\r\n");
                delay(5000);
            } else {
              gps.encode(ss.read());
              float a=gps.location.lat();
              float b=gps.location.lng();
              Serial.println(a);
              Serial.println(b);
              char cmd[128];
              sprintf(cmd, "AT+CMSGHEX=\"%04X%04X\"\r\n", (float)a,(float)b);
              ret = at_send_check_response("Done", 5000, cmd);
              if (ret) {
                recv_prase(recv_buf);
              } else {
                Serial.print("Send failed!\r\n\r\n");
              delay(5000);
          } else {
            delay(1000);
          salmanfaris @zainmuhammed last edited by
          Hi @zainmuhammed ,
          • zainmuhammed
            zainmuhammed @salmanfaris last edited by
            @salmanfaris Today I tried after connecting a 18650 cell,
              salmanfaris @zainmuhammed last edited by salmanfaris
              @zainmuhammed Can try capturing the GPS when the device is starting the loop instead after joining the LoRaWAN and see?
              • Facility Management Software is designed to help organizations efficiently manage buildings, assets, and daily operations from a centralized platform. It enables teams to automate maintenance activities, track assets in real time, manage work orders, and schedule preventive maintenance to reduce downtime and operational costs. With integrated tools for space management, inventory control, vendor coordination, and compliance tracking, the software ensures smooth and uninterrupted facility operations.
                By providing real-time data and performance insights, Facility Management Software supports informed decision-making and improves resource utilization. It enhances productivity, extends asset lifespan, and ensures safety and regulatory compliance across facilities. Suitable for industries such as manufacturing, healthcare, IT, hospitality, education, and commercial real estate, the solution simplifies complex facility workflows and helps organizations achieve operational efficiency, sustainability, and long-term cost control.
                Mumbai Escorts
                Mira Road Escorts
                Udaipur Escorts
                Rajkot Escorts
                Bhubaneswar Escorts
                Andheri Escorts
                Ahmedabad Escorts
                Nariman Point Escorts
                Bandra Escorts
                Airoli Escorts
                Ambernath Escorts
                Badlapur Escorts
                Belapur Escorts
                Bhandup Escorts
                Bhayandar Escorts
                Borivali Escorts
                Chembur Escorts
                Colaba Escorts
                Cotton Green Escorts
                Dadar Escorts
                Dahisar Escorts
                Diva Escorts
                Dombivali Escorts
                Ghansoli Escorts
                Goddbonder Road Escorts
                Goregaon Escorts
                Govandi Escorts
                Gtb Nagar Escorts
                Indore Escorts
                Juhu Escorts
                Kalamboli Escorts
                Kalwa Escorts
                Kalyan Escorts
                Kashimira Escorts
                Kopar Khairane Escorts
                Kurla Escorts
                Lokhandwala Escorts
                Malad Escorts
                Mankhurd Escorts
                Masjid Bunder Escorts
                Mulund Escorts
                Mumbra Escorts
                Nahur Escorts
                Navi Mumbai Escorts
                Nerul Escorts
                Panve Escortsl Escorts
                Powai Escorts
                Rabale Escorts
                Sanpada Escorts
                Santa Cruz Escorts
                Seawood Escorts
                Taloja Escorts
                Thane Escorts
                Tilak Nagar Escorts
                Turbhe Escorts
                Ulhasnagar Escorts
                Vartak Nagar Escorts
                Vashi Escorts
                Vikhroli Escorts
                Vile Parle Escorts
                Wadala Road Escorts
                Bangalore Escorts
                Delhi Escorts
                Gurgaon Escorts
                Hyderabad Escorts
                Jaipur Escorts
                Kolkata Escorts
                Lucknow Escorts
                Noida Escorts
                Patna Escorts
                Pune Escorts
                Ranchi Escorts
                Surat Escorts
                Bhopal Escorts
                Ghaziabad Escorts
                Allahabad Escorts
                Mumbai Escorts
                Mount Abu Escorts
                Indore Escorts
                Udaipur Escorts
                Mumbai Call Girls
                Mumbai Call Girls
                Call Girls in Mumbai
                Pune Escorts
                Hyderabad Escorts
                Andheri Escorts
                Andheri Escorts
                Chennai Escorts
                Mumbai Escorts
                Jalandha Escorts
                Jamshedpur Escorts
                Varanasi Escorts
                Rishikesh Escorts
                Zirakpur Escorts
                Vadodara Escorts
                Mount Abu Escorts
                Ajmer Escorts
                Dehradun Escorts
                Manali Escorts
                Jammu Escorts
                Haridwar Escorts
                Kochi Escorts
                Vijayawada Escorts
                Visakhapatnam Escorts
                Mathura Escorts
                Raipur Escorts
                Daman Escorts
                Shimla Escorts
                Agra Escorts
                Indore Escorts
                Indore Escorts
                Chennai Escorts
                Indore Escorts
                Ujjain Escorts
                Badnawar Escorts
                Badnagar Escorts
                Shajapur Escorts
                Dewas Escorts
                Nagda Escorts
                Ratlam Escorts
                Sillod Escorts
                Jalgaon Escorts
                Bhusawal Escorts
                Amalner Escorts
                Ahmednagar Escorts
                Dhule Escorts
                Jalna Escorts
                Udaipur Escorts
                Kutch Escorts
                Somnath Escorts
                Porbandar Escorts
                Aurangabad Escorts
                Sabarmati Escorts
                Cg Road Escorts
                Vastrapur Escorts
                Naroda Escorts
                Narol Escorts
                Sg Highway Escorts
                Gota Escorts
                Chandkheda Escorts
                Ambawadi Escorts
                Asarwa Escorts
                Ashram Road Escorts
                Satellite Escorts
                Sarkhej Escorts
                Paldi Escorts
                Sola Escorts
                Ranip Escorts
                Shahpur Escorts
                Thaltej Escorts
                Vasna Escorts
                Maninagar Escorts
                Chopda Escorts
                Chennai Escorts
                Jalandhar Escorts
                Jammu Escorts
                Jhansi Escorts
                Karnal Escorts
                Kota Escorts
                Kullu Escorts
                Laddakh Escorts
                Leh Escorts
                Manipur Escorts
                Meerut Escorts
                Meghalaya Escorts
                Mount Abu Escorts
                Muzaffarnagar Escorts
                Mysore Escorts
                Nagpur Escorts
                Nainital Escorts
                Nashik Escorts
                Navi Mumbai Escorts
                Ooty Escorts
                Pathankot Escorts
                Pondicherry Escorts
                Shimla Escorts
                Sikkim Escorts
                Siliguri Escorts
                Champaner Escorts
                Veraval Escorts
                Surat Escorts
                Vadodara Escorts
                Ahmedabad Escorts
                Agra Escorts
                Dehradun Escorts
                Gurgaon Escorts
                Hyderabad Escorts
                Jaipur Escorts
                Jodhpur Escorts
                Kanpur Escorts
                Kolkata Escorts
                Lucknow Escorts
                Goa Escorts
                Mumbai Escorts
                Mussoorie Escorts
                Raipur Escorts
                Delhi Escorts
                Ranchi Escorts
                Rishikesh Escorts
                Ajmer Escorts
                Allahabad Escorts
                Almora Escorts
                Alwar Escorts
                Ambala Escorts
                Amravati Escorts
                Bareilly Escorts
                Bathinda Escorts
                Bhilai Escorts
                Bhopal Escorts
                Bbhubaneswar Escorts
                Bikaner Escorts
                Bilaspur Escorts
                Coimbatore Escorts
                Chandigarh Escorts
                Daman Escorts
                Darjeeling Escorts
                Gangtok Escorts
                Gorakhpur Escorts
                Noida Escorts
                Guwahati Escorts
                Haldwani Escorts
                Hapur Escorts
                Imphal Escorts
                Jabalpur Escorts
                Jaisalmer Escorts
                Anand Escorts
                Gandhidham Escorts
                Mehsana Escorts
                Morbi Escorts
                Palitana Escorts
                Ambaji Escorts
                Vapi Escorts
                Ankleshwar Escorts
                Adalaj Escorts
                Dahod Escorts
                Amreli Escorts
                Dakor Escorts
                Botad Escorts
                Kandla Escorts
                Diu Escorts
                Mandvi Escorts
                Anjar Escorts
                Himmatnagar Escorts
                Panchmahal Escorts
                Sonipat Escorts
                Srinagar Escorts
                Tirupati Escorts
                Tripura Escorts
                Varanasi Escorts
                Zirakpur Escorts
                Kochi Escorts
                Airoli Escorts
                Andheri Escorts
                Bandra Escorts
                Belapur Escorts
                Borivali Escorts
                Chembur Escorts
                Colaba Escorts
                Dadar Escorts
                Dahisar Escorts
                Dharavi Escorts
                Ghatkopar Escorts
                Goregaon Escorts
                Grant Road Escorts
                Gondal Escorts
                Navsari Escorts
                Palanpur Escorts
                Valsad Escorts
                Nadiad Escorts
                Godhra Escorts
                Saputara Escorts
                Juhu Escorts
                Kandivali Escorts
                Khar Escorts
                Kharghar Escorts
                Kurla Escorts
                Lokhandwala Escorts
                Mahim Escorts
                Malad Escorts
                Marine Drive Escorts
                Mira Road Escorts
                Mulund Escorts
                Nerulpanvel Escorts
                Powai Escorts
                Sakinaka Escorts
                Santacruz Escorts
                Seawood Escorts
                Vasai Escorts
                Vashi Escorts
                Vileparle Escorts
                Wadala Escorts
                Worli Escorts
                Rajkot Escorts
                Junagadh Escorts
                Jamnagar Escorts
                Bhavnagar Escorts
                Gandhinagar Escorts
                Bhuj Escorts
                Bharuch Escorts
                Bangalore Escorts
