    Pump motor doesn't run via gpio
      rahuleapen last edited by
      Arduino has been compiled to run a motor pump. The pump seems to be working fine via the 5v and ground port with appropriate voltage and current. The same voltage and current is seen across the gpio whenever turned high but the motor doesn't run via gpio. Can anyone help me out here..please it's urgent
        salmanfaris @rahuleapen last edited by
        @rahuleapen Can you please share the connection diagram?
