    Gaming steering wheel setup
    2302
      salmanfaris @Vipin I V last edited by salmanfaris
      @vipin-i-v What about following the tutorial you mentioned?
      V 1 Reply Last reply Reply Quote 0
      • V
        Vipin I V @salmanfaris last edited by
        @salmanfaris i guess yes...that would be the best and suitable for me..
          @vipin-i-v I think so, let us know the updates!
          swalahamani 1 Reply Last reply Reply Quote 0
          • swalahamani
            swalahamani @salmanfaris last edited by
            Hi @Vipin-I-V ,
            This seems to be an interesting project.
            Please share the development here...
            I was thinking of something similar, but not for gaming. Won't it be cool to have the Ctrl, Cmd & Alt keys as pedals? Please share your thoughts & insights.
