    Uploading data to firebase using NodeMCU
    3961
      Anudeep @Palani last edited by
      Hello @Palani, In the Firebase, there are two types of storage,
      1. Cloud Firestore (Very recent one & NoSQL database)
      2. Realtime Database (To which we upload the data using NodeMCU)
      In the Arduino Code, you can see that there is a variable named FIREBASE_AUTH.
      This variable should be assigned to the Database secret. This you can find in Project Settings -> Service accounts -> Database Secrets.
      My mistake is, i have mistakenly assigned thay to Web API key. This is found at Project Settings -> General.
      The error can also occur when u don't initialise a proper realtime database in Firebase. (This is not my case).
      P 1 Reply Last reply Reply Quote 0
      • P
        Palani @Anudeep last edited by
        @Anudeep Thanks a lot m8, I actually made a very silly mistake of including the https:// while entering FIREBASE_HOST, where I must have entered the Domain name alone and removed the https:// extension.
        Thanks again for replying that quick. Cheers.
