    Uploading data to firebase using NodeMCU
    4149
      salmanfaris @Anudeep last edited by
      @Anudeep Ok , compilation part is clear .did you getting anything on the firebase side ? Any erros ?
      A 2 Replies Last reply Reply Quote 0
        Anudeep @salmanfaris last edited by
        @salmanfaris Nothing, No errors!!
        Do I need to change anything in Firebase settings or something?
          @salmanfaris Thanks for the support!!
          I finally resolved the error. I have taken FIREBASE_AUTH as apiKey instead of Database secrets.
          salmanfaris P 2 Replies Last reply Reply Quote 2
            @Anudeep Great . Glad to know that it is solved , Keep hacking 🤖
            • P
              Palani @Anudeep last edited by
              @Anudeep Hello Anudeep could you please help me out by elaborating the fix to get rid of that error?
              Thanks in advance.
                Anudeep @Palani last edited by
                Hello @Palani, In the Firebase, there are two types of storage,
                1. Cloud Firestore (Very recent one & NoSQL database)
                2. Realtime Database (To which we upload the data using NodeMCU)
                In the Arduino Code, you can see that there is a variable named FIREBASE_AUTH.
                This variable should be assigned to the Database secret. This you can find in Project Settings -> Service accounts -> Database Secrets.
                My mistake is, i have mistakenly assigned thay to Web API key. This is found at Project Settings -> General.
                The error can also occur when u don't initialise a proper realtime database in Firebase. (This is not my case).
                P 1 Reply Last reply Reply Quote 0
                • P
                  @Anudeep Thanks a lot m8, I actually made a very silly mistake of including the https:// while entering FIREBASE_HOST, where I must have entered the Domain name alone and removed the https:// extension.
                  Thanks again for replying that quick. Cheers.
