    help me to find a FPGA dev board for getting started suggest me a cheap and best dev board?
    • saheen_palayi
      saheen_palayi last edited by
      i'm new to the FPGA world ,looking for a fpga dev board to getting started ,I hope u guys will help me to find out ,thanks
        Hi @saheen_palayi , It depends on what exactly you want to do with the FPGA kit. and don't have much experience with FPGA, but I can help you Lattice iCEstick Evaluation Kit to get started.
        It's available at fablab Kochi and Trivandrum if you want to try it out without buying.
        alt text alt text
        Features
        The iCEstick Evaluation Kit includes:
        • iCEstick Evaluation Board – features the following on-board components
        – High-performance, low-power iCE40HX1K FPGA
        – FTDI 2232H USB device allows iCE device programming and UART interface to a PC
        – Vishay TFDU4101 IrDA transceiver
        – Five user LEDs
        – 2 x 6 position Diligent PmodTM compatible connector enables many other peripheral connections
        – Discera 12Mhz MEMS oscillator
        – Micron 32Mbit N25Q32 SPI flash
        – Supported by Lattice iCEcube2™ design software
        – USB connector provides the power supply
        – 16 LVCMOS/LVTTL (3.3V) digital I/O connections on 0.1” through-hole connections
        • Pre-loaded demo design – the kit includes the pre-loaded demo design that flashes the on-board LEDs in a
        clockwise pattern.
        • USB connector – provides communication and debug port via a USB-to-RS-232 physical channel and programming interface to the PC.
        resources :
        • https://www.allaboutcircuits.com/technical-articles/fpga-tutorial-step-1-the-development-environment-and-hello-world/
        • https://numato.com/kb/learning-fpga-verilog-beginners-guide-part-1-introduction/
        • https://www.sparkfun.com/news/1203
        • https://www.quora.com/What-is-the-best-affordable-FPGA-dev-kit-for-a-starter
          goran.mahovlic last edited by goran.mahovlic
          Our board is not cheapest possible, but has lots of things already onboard.
          ULX3S
          Board is also supported by opensource toolchain!
          For workshop material with our board you can check here:
          Workshop
          Price for 12F board is 75€ plus shipping.
          If you like it you can contact me at:
          ulx3s.fpga@gmail.com
