    Error While writing Library for Gy521
    2435
      rafitc99 @salmanfaris last edited by rafitc99
      @salmanfaris forgot to call function getAcData() and getGyData() before goo.AcX... 😂
        ohh 😀 , Glad to know that it's working fine, Thanks to @vishnumaiea and @saheen_palayi . 🤘
