    How to define angle for 995 360deg continuous servo?
    • H
      hydro-bob last edited by
      In the 995 datasheet , angular velocity = 0.17s/60 Deg (5 volt)
      := 180 deg = 0.51s But practically I’m getting 805s
      And other angles are as follows (irl)
      425s = 90deg
      805s = 180deg
      1130s = 270deg
      1475s = 360deg
      I want to know why it’s not consistent and (if it’s not a mistake of mine) could I get a formula for the time to degree
      Thanks for your time 😊
        @hydro-bob Can you post the details of servo like datasheet of the servo you're using?
        • H
          https://www.electronicoscaldas.com/datasheet/MG995_Tower-Pro.pdf
          It’s normal mg 995 servo
            Hi @hydro-bob , did find the solution?
