    Error on Raspberry PI 4 while opening TensorFlow.
    5554
      sreu13 last edited by salmanfaris
      Hi,
      I came by this error after installing TensorFlow in RPI 4
      can you guys find a fix?
      error on Raspberry PI 4
      tensorflow/core/platform/hadoop/hadoop_file_system.cc:132] HadoopFileSystem load error: libhdfs.so: cannot open shared object file: No such file or directory)
        arunksoman last edited by
        Your are using a bleeding edge python software for tensorflow. I believes it is python 3.7 or python 3.8 or something. Try to downgrade your python to 3.6.5 or other compatible version by refereing documentation.
          sreu13 @arunksoman last edited by
          @arunksoman hi, i've run this code using python 3.7 on anaconda and it worked fine.
          but as i run this on RPI 4, it showed the Hadoop error. I then updated the libraries and Hadoop error was solved..
          now there is a new error
          also can you take a look in the 10% memory error?...like what can be possibly done there??
          A 1 Reply Last reply Reply Quote 0
            arunksoman @sreu13 last edited by
            @sreu13 What is the version of tensorflow you are using? Did you read the tensorflow docs? You can't do simply
            pip install tensorflow
            for Python 3.7 version.
            S 2 Replies Last reply Reply Quote 0
              @arunksoman i installed tensorflow from the below given link
              https://maker.pro/raspberry-pi/projects/how-to-set-up-the-machine-learning-software-tensorflow-on-raspberry-pi
              and i installed it without entering into virtual environment
              but this 10% memory issue is a serious pain
                  arunksoman @sreu13 last edited by arunksoman
                  1. sudo raspi-config
                  2. Navigate to Advanced options
                  3. Select advanced options and hit enter(I believes tab key is useful here)
                  4. Choose Expand File System and hit enter finish.
                  5. Then your pi may prompt to reboot. If it didn't run. Execute
                    sudo reboot
                  6. Then execute following commands one by one:
                  $ sudo apt-get purge wolfram-engine
                  $ sudo apt-get purge libreoffice*
                  $ sudo apt-get clean
                  $ sudo apt-get autoremove
                  1. Then increase swap memory by editing following file swapfile:
                    $ sudo nano /etc/dphys-swapfile
                  2. It will open nano editor. Navigate to variable
                  CONF_SWAPSIZE=100
                  #CONF_SWAPSIZE=100
                  CONF_SWAPSIZE=2048
                  1. Save the file and exit nano editor.
                  2. sudo reboot
                        1. sending image from rpi4 to cloud
                        2. using this cloud for running prediction
                        3. the above two processes should be automated and image should be sent to cloud when pi boots up(VM engine can be activated whenever nessesary)
                        • MatjarX is a results-driven web development company in Karachi focused on helping small businesses get online quickly and affordably. We specialize in done-for-you websites built in just 7 days, combining strategic design, technical development, SEO services, website concierge assistance, and growth marketing under one roof. Our team of global professionals works closely with clients to remove the stress of launching and managing a website, ensuring every business has the tools, visibility, and ongoing support needed to grow confidently in the digital world.
