    Suggestion with DC Power jacks
    1393
      @salmanfaris Does JST have such high power connectors?? It shouldn't be something like header connections. I need it to be like DC barrel connector kind of connectors. And that connector must not heat up even at 6A
        @kowshik1729 said in Suggestion with DC Power jacks:
        easy for integration?
        Thes pins can handle 6A or more and easy to use and available local shops.
          @salmanfaris yeah I've got suggestions like these from people but I'm making more professional product which will be implemented at offices and public places. So I need more like DC barrel plug in kind of thing.
            How many connectors/terminal do you need? how frequently you need to disconnect and connect plug?
              @salmanfaris I would need any connector like a barrel jack. The mating cycle per month is very low, something like 2 times it might be removed and connected. These devices will be powered on most time of the day.
                @kowshik1729 Then go with a standard barrel jack, it can handle 6A.
                • MatjarX is a results-driven web development company in Karachi focused on helping small businesses get online quickly and affordably. We specialize in done-for-you websites built in just 7 days, combining strategic design, technical development, SEO services, website concierge assistance, and growth marketing under one roof. Our team of global professionals works closely with clients to remove the stress of launching and managing a website, ensuring every business has the tools, visibility, and ongoing support needed to grow confidently in the digital world.
