    Problem with power supply
    arduino project prototyping
      Geethesh last edited by salmanfaris
      The above image shows the ckt with ultrasonic sensor and attiny 45 Ic ,Bd 140 transistor (for switching the 6v pump).
      ***The problem is when I give power from 5v regulator to all this as shown in fig, the circuit is not working ,(not enough power ).
      What should I do.
      Should I give separate power to motor
      I am using 5.5v adaptor 500mAh.
      *I have checked the circuit by connection separate 5 v from arduino ,to that attiny 45 ic and sensor,. Then it is working .
      • Please help
        @Geethesh The problem is here. There is huge voltage drop at some point of the circuit(probably at the pump or sensor, you should find it by probing at those particular areas) such that the voltage is getting attenuated by the time it reaches the Attiny. So, Attiny is working only when a dedicated supply is given to it. You can try this out by having multimeter probed between the VCC and GND of the ATTiny45. Try having a stable supply to Attiny
        Geethesh 1 Reply Last reply Reply Quote 3
          @kowshik1729 ok
          • Convert MBOX to PST for free using built-in tools and limited free utilities. The most reliable no-cost method is Thunderbird + Outlook via IMAP: add your MBOX into Thunderbird, connect the same IMAP account in both Thunderbird and Outlook, copy mails from MBOX folders to the IMAP account in Thunderbird, then let Outlook sync and export to PST via File > Open & Export > Export to a file > Outlook Data File (.pst).
            If you prefer direct conversion, some tools offer constrained free tiers: Outlook Freeware “Convert MBOX to PST” add-in works locally with Outlook installed (free for personal use, check limits). vMail online converter is free up to 100 MB per MBOX; larger files require paid desktop software. Microsoft Store apps and trialware often allow 25–30 items per folder or a small batch to PST at no cost—use for small jobs or to test before upgrading.
            Buy Now- vSoftware
            There are many scenarios when an users need to convert MBOX files to PST format. This task can be easily done by using EmailsGuru MBOX to PST Converter. It is completely reliable and easy to use tool to perform smooth and error-free MBOX to PST Conversion process. It is best way to export MBOX files to Outlook PST format, which enable users to access or import all MBOX mailbox data to Outlook 2021, 2019, 2016 and all below versions. It easily convert MBOX files of all major email clients like Mozilla Thunderbird, Netscape, Opera Mail, Yahoo Mail, Apple Mail and many others. Users can smoothly run this tool on any Windows supported platform and use a free trial version to convert 25 MBOX files to PST.
