    Help needed in MIT App Inventor
    arduino bluetooth application
      Geethesh last edited by Geethesh
      I want to make a app in mit app inventor ,to connect Bluetooth module HC05 . I just manage to make it
      My key finder app
      Screen shots of app
      But I want the app to make alert tune when the hc05 get disconnected from phone.
        Hi @Geethesh, Did you find any solution?
