    [Solved] leaf disease detection using keras
    5308
      sreu13 @arunksoman last edited by
      @arunksoman
      by multiprocessing, do you mean to use multilabel binarizer, if yes , then I have already used it during the training process.
      @SuperGops , fit_transform has also been used in the code prior to using label_binarizer.
        arunksoman @sreu13 last edited by
        @sreu13 I didn't mean that. I said if you are trying to run your code on RasPi4 or any other version of RasPi, you have to do some optimization on the code for better performance. Then Multiprocessing and threading Module comes into the picture.
          @arunksoman
          i followed your proceedure to and installed the requirements.txt file
          after running the code, I got the following error
          File "C:\Users\admin\Anaconda3\envs\test2\lib\site-packages\scipy\special\basic.py", line 15, in <module>
          from ._ufuncs import (ellipkm1, mathieu_a, mathieu_b, iv, jv, gamma,
          ImportError: cannot import name 'ellipkm1'
            arunksoman @sreu13 last edited by arunksoman
            @sreu13 I didn't tell you to install anything via anaconda package manager. You have to uninstall those things first and install python 3.6.5. It was the first step.You have to read things carefully before executing anything.
              @sreu13 how is the progress?
                sreu13 @salmanfaris last edited by
                @salmanfaris i know there was a delay in replies, i thought of finishing the project and replying here!....
                i ddnt get the exact reason, but the problem was solved
                what i did was , label binarized was working fine when i did created the training model. So i loaded my training model and deleted the script for the training procedure. i ended up with the code given below. and it worked up fine.
                import numpy as np
                import pickle
                import cv2
                from os import listdir
                from sklearn.preprocessing import LabelBinarizer
                from keras.models import Sequential
                from keras.layers.normalization import BatchNormalization
                from keras.layers.convolutional import Conv2D
                from keras.layers.convolutional import MaxPooling2D
                from keras.layers.core import Activation, Flatten, Dropout, Dense
                from keras import backend as K
                from keras.preprocessing.image import ImageDataGenerator
                from keras.optimizers import Adam
                from keras.preprocessing import image
                from keras.preprocessing.image import img_to_array
                from sklearn.preprocessing import MultiLabelBinarizer
                from sklearn.model_selection import train_test_split
                import matplotlib.pyplot as plt
                EPOCHS = 25
                INIT_LR = 1e-3
                BS = 32
                default_image_size = tuple((256, 256))
                image_size = 0
                directory_root = 'PlantVillage'
                width=256
                height=256
                depth=3
                #Function to convert images to array
                def convert_image_to_array(image_dir):
                    try:
                        image = cv2.imread(image_dir)
                        if image is not None :
                            image = cv2.resize(image, default_image_size)
                            return img_to_array(image)
                        else :
                            return np.array([])
                    except Exception as e:
                        print(f"Error : {e}")
                        return None
                listdir(directory_root)
                image_list, label_list = [], []
                try:
                    print("[INFO] Loading images ...")
                    root_dir = listdir(directory_root)
                    for directory in root_dir :
                        # remove .DS_Store from list
                        if directory == ".DS_Store" :
                            root_dir.remove(directory)
                    for plant_folder in root_dir :
                        plant_disease_folder_list = listdir(f"{directory_root}/{plant_folder}")
                        for disease_folder in plant_disease_folder_list :
                            if disease_folder == ".DS_Store" :
                                plant_disease_folder_list.remove(disease_folder)
                        for plant_disease_folder in plant_disease_folder_list:
                            print(f"[INFO] Processing {plant_disease_folder} ...")
                            plant_disease_image_list = listdir(f"{directory_root}/{plant_folder}/{plant_disease_folder}")
                            for single_plant_disease_image in plant_disease_image_list :
                                if single_plant_disease_image == ".DS_Store" :
                                    plant_disease_image_list.remove(single_plant_disease_image)
                            for image in plant_disease_image_list[:200]:
                                image_directory = f"{directory_root}/{plant_folder}/{plant_disease_folder}/{image}"
                                if image_directory.endswith(".jpg") == True or image_directory.endswith(".JPG") == True:
                                    image_list.append(convert_image_to_array(image_directory))
                                    label_list.append(plant_disease_folder)
                    print("[INFO] Image loading completed")
                image_size = len(image_list)
                #Transform Image Labels uisng Scikit Learn's LabelBinarizer
                label_binarizer = LabelBinarizer()
                image_labels = label_binarizer.fit_transform(label_list)
                pickle.dump(label_binarizer,open('label_transform.pkl', 'wb'))
                n_classes = len(label_binarizer.classes_)
                #Print the classes
                print(label_binarizer.classes_)
                #load saved pickle model
                loaded_model = pickle.load(open('cnn_model.pkl', 'rb'))
                model_disease=loaded_model
                #load plant leaf image
                image_dir="plantdisease/Validation_Set/Potato___Early_blight/1d301622-e359-49d5-b4ca-6837f254fd1b___RS_Early.B 6719.JPG"
                #convert leaf image to arrays
                im=convert_image_to_array(image_dir)
                np_image_li = np.array(im, dtype=np.float16) / 225.0
                npp_image = np.expand_dims(np_image_li, axis=0)
                result=model_disease.predict(npp_image)
                print(result)
                #printing result
                itemindex = np.where(result==np.max(result))
                print("probability:"+str(np.max(result))+"\n"+label_binarizer.classes_[itemindex[1][0]])
                • MatjarX is a results-driven web development company in Karachi focused on helping small businesses get online quickly and affordably. We specialize in done-for-you websites built in just 7 days, combining strategic design, technical development, SEO services, website concierge assistance, and growth marketing under one roof. Our team of global professionals works closely with clients to remove the stress of launching and managing a website, ensuring every business has the tools, visibility, and ongoing support needed to grow confidently in the digital world.
