    [Solved] Help needed for face detection -deep learning
    2679
    • Nandu
      Nandu last edited by salmanfaris
      I have a code for detecting faces but now i need to count no:of faces .link text
      # OpenCV Python program to detect cars in video frame
      # import libraries of python OpenCV
      import cv2
      #import numpy as np
      # capture frames from a video
      cap = cv2.VideoCapture('video.avi')
      # Trained XML classifiers describes some features of some object we want to detect
      car_cascade = cv2.CascadeClassifier('cars.xml')
      # loop runs if capturing has been initialized.
      while True:
          # reads frames from a video
          ret, frames = cap.read()
          # convert to gray scale of each frames
          gray = cv2.cvtColor(frames, cv2.COLOR_BGR2GRAY)
          #color fill white
          frames.fill(255)
          # or img[:] = 255
          # Detects cars of different sizes in the input image
          cars = car_cascade.detectMultiScale(gray, 1.1, 1)
          # To draw a rectangle in each cars
          for (x,y,w,h) in cars:
              cv2.rectangle(frames,(x,y),(x+w,y+h),(0,0,0),-1)
         # Display frames in a window
          cv2.imshow('video2', frames)
          # Wait for Esc key to stop
          if cv2.waitKey(33) == 27:
              break
      # De-allocate any associated memory usage
      cv2.destroyAllWindows()
        Hi @Nandu, You can increment a variable each time when detect faces, is that help?
        Nandu 1 Reply Last reply Reply Quote 0
        • Nandu
          Nandu @salmanfaris last edited by
          @salmanfaris yeah that's what i want.But i am not able to understand where i should place my variable in the above mentioned code.
            Follow These steps
            1. Create a virtual enviroment and activate virtial environment
            python -m venv venv
            Activate venv for windows using following command:
            .\venv\Scripts\activate
            For Ubuntu:
            source venv/bin/activate
            1. Install necessary packages on venv
            pip install opencv-python
            pip install imutils
            1. Create Folder structure as shown below in your workspace
            TestPrograms
            ├─ cascades
            │  └─ haarcascade_frontalface_default.xml
            ├─ detect_faces.py
            ├─ images
            ├─ utilities
            │  └─ facedetector.py
            1. Program for utililities/facedetector.py given below:
            import cv2
            class FaceDetector:
                def __init__(self, face_cascade_path):
                    # Load the face detector
                    self.face_cascade = cv2.CascadeClassifier(face_cascade_path)
                def detect(self, image, scale_factor=1.2, min_neighbors=3):
                    # Detect faces in the image
                    boxes = self.face_cascade.detectMultiScale(image, scale_factor, min_neighbors, flags=cv2.CASCADE_SCALE_IMAGE, minSize=(30,30))
                    # Return the bounding boxes
                    return boxes
            1. program on detect_faces.py
            from utilities.facedetector import FaceDetector
            import imutils
            import cv2
            # Define paths
            image_path = 'images/obama.jpg'
            cascade_path = 'cascades/haarcascade_frontalface_default.xml'
            # Load the image and convert it to greyscale
            image = cv2.imread(image_path)
            image = imutils.resize(image, 600, 600)
            gray = cv2.cvtColor(image, cv2.COLOR_BGR2GRAY)
            # Find faces in the image
            detector = FaceDetector(cascade_path)
            face_boxes = detector.detect(gray, 1.2, 5)
            print("{} face(s) found".format(len(face_boxes)))
            # Loop over the faces and draw a rectangle around each
            for (x, y, w, h) in face_boxes:
                cv2.rectangle(image, (x, y), (x + w, y + h), (0, 255, 0), 2)
            # Show the detected faces
            cv2.imshow("Faces", image)
            if(cv2.waitKey(0)):
            1. Links to necessary files:
              Haar cascade frontal face
              Obama Family Image
            Nandu 1 Reply Last reply Reply Quote 2
            • Nandu
              Nandu @arunksoman last edited by
              @arunksoman thankyou 🥳
                arunksoman @Nandu last edited by
                @Nandu But I have to mention that it is not a deep learning method. It is based on Integral images(Viola-Jones algorithm), which is basically something about ML. From opencv 3.4.3 there is a DNN module. This module help us to load caffemodels, torch models as well as tensorflow models. You can find out caffemodels on the Internet in order to detect faces. Using those we can make face detection quite efficiently. If you have any doubt feel free to ask here.
                • Nandu
                  @arunksoman how this code helps me to count faces if deeplearning isn't used.
                    arunksoman @Nandu last edited by arunksoman
                    @Nandu Please read the comment given above carefully and search how the viola-jones algorithm works. Sorry for misunderstanding what you say. That is why edited comment.
                      @Nandu Did you complete? excited to see.
                      • Nandu
                        Nandu @salmanfaris last edited by salmanfaris
                        @salmanfaris in the below terminal count shows.some steps i have followed in a different manner.Thank you for helping me!🙂
                        A 1 Reply Last reply Reply Quote 1
                        • Convert MBOX to PST for free using built-in tools and limited free utilities. The most reliable no-cost method is Thunderbird + Outlook via IMAP: add your MBOX into Thunderbird, connect the same IMAP account in both Thunderbird and Outlook, copy mails from MBOX folders to the IMAP account in Thunderbird, then let Outlook sync and export to PST via File > Open & Export > Export to a file > Outlook Data File (.pst).
                          If you prefer direct conversion, some tools offer constrained free tiers: Outlook Freeware “Convert MBOX to PST” add-in works locally with Outlook installed (free for personal use, check limits). vMail online converter is free up to 100 MB per MBOX; larger files require paid desktop software. Microsoft Store apps and trialware often allow 25–30 items per folder or a small batch to PST at no cost—use for small jobs or to test before upgrading.
                          Buy Now- vSoftware
                          There are many scenarios when an users need to convert MBOX files to PST format. This task can be easily done by using EmailsGuru MBOX to PST Converter. It is completely reliable and easy to use tool to perform smooth and error-free MBOX to PST Conversion process. It is best way to export MBOX files to Outlook PST format, which enable users to access or import all MBOX mailbox data to Outlook 2021, 2019, 2016 and all below versions. It easily convert MBOX files of all major email clients like Mozilla Thunderbird, Netscape, Opera Mail, Yahoo Mail, Apple Mail and many others. Users can smoothly run this tool on any Windows supported platform and use a free trial version to convert 25 MBOX files to PST.
