    Soil level measurements under water
    project prototyping arduino
      Geethesh last edited by
      I want to make a device which measure the level or quantity of soil deposited under a tank containing water (sedimentation). Any one help please.
        @Geethesh I guess you have asked the same application with a different name "Water Depth Sensor". But anyways, You can use Sharp IR sensor for calculating the sedimented soil in a water tank.
          @kowshik1729 ok
            Did you find the sensor?
            Geethesh 1 Reply Last reply Reply Quote 0
              Geethesh @salmanfaris last edited by
              No
                @Geethesh I was talking about this sensor.👇
                Sharp GP2Y0A21YK0F
