    DTDS-622C MEVB Lora modam programing
    Development Boards
      sarathslab last edited by sarathslab
      Hai iam Sarath Santhosh
      Can anyone please help me out by giving the details about how to program this device(DTDS-622-MEVB) for sending and receive data, I also want to know about how the data packets are handled. This is for a project related to smart metering I just want to setup a gateway for that.
      I want to know about the details of how I can set up the gateway.!
      swalahamani 1 Reply Last reply Reply Quote 0
        swalahamani @sarathslab last edited by
        @sarathslab said in DTDS-622C MEVB Lora modam programing:
        DTDS-622-MEVB
        Hi @sarathslab ,
        Thanks for asking on MakerGram Community Forum!
        Is this is the one you're using?
        https://dtdsgp.com/lora-module/
          sarathslab @swalahamani last edited by
          @swalahamani yes
            @sarathslab Did you check the documentation?
            If not please check those first and post the issues or blockers you're facing while doing it here.
              swalahamani @swalahamani last edited by
              @swalahamani
              @zainmuhammed @salmanfaris You may be able to help with this.
              • zainmuhammed
                zainmuhammed last edited by
                @sarathslab why your are choosing this perticular LoRa module, can you please elaborate your use case. Personally I don't have experience with this module. When i go through the details of this hardware find like this is a UART device and so you can communicate by using the AT comments. And this will be available on the datasheet I guess. Also if you don't want to use this perticular module I suggest sx1276 or LoRa E5 from Seeedstudio. And by using this you can able to connect with helium network or things network. If you want to know more about this I think Salman can help.
                • @Vishnuraj2003 Are you able to fix it?
                • Hi @Vishnuraj2003 ,
                  As per the documentation, I think we only route the data over the LoRa oR BT. The Wifi is used for sniffing access points for better geo-location and positioning along with GPS.
                  And what is the issue you facing when connecting the tracker with gateway? Double check the FREQ on both node and gateway configuration
                • I'm working with Seeed Studio's Wio Tracker 1110 Dev Board. According to Seeed Studio's documentation, we can use the Wi-Fi antenna inside the Wio Tracker to send data. However, when I used the Sensecraft app, it shows that the board is offline. I have tried connecting it to the Sensecap M2 Gateway but couldn't do it due to a lack of documentation. Please share any advice or resources that could help. Thank you.
                • @binishmatheww All the best. Let us know if you need any help.
                • @salmanfaris thanks a lot. 👍😁
