    Can't connect NodeMCU with MQTT
    3431
      sivanath @swalahamani last edited by sivanath
      @swalahamani @salmanfaris
      I changed my conf file and specified ipv4
      And this is the status of the port (from resource monitor):
      Image: mosquitto.exe
      PID: 3732
      Address: IPv6 loopback
      Protocol: TCP
      Port: 1883
      Firewall Status: Allowed, not restricted
      It is listening to mosquito..
      swalahamani 1 Reply Last reply Reply Quote 0
        swalahamani @sivanath last edited by
        @sivanath
        Is it working now?
            @sivanath
            Did you follow the steps which I mentioned previously?
              @swalahamani Yeah!!
                swalahamani @sivanath last edited by swalahamani
                @sivanath
                Oh okay.
                Please bring your device if you're coming for the upcoming MakerChat 0x13 tomorrow (IST). Either I and @salmanfaris or both of us will be there.
                Or else we can set up a call sometime this weekend or the next week and sort it out.
                Let me know.
                  @swalahamani I may not be able to come tomorrow. I think we could set up a call. How can I contact you personally?
                    salmanfaris @sivanath last edited by
                    @sivanath From your last message looks like the MQTT broker already running on your computer. Could you please try to do a test with nodeRED and see it's working or not.
                      sivanath @salmanfaris last edited by
                      @salmanfaris Actually, I can't connect my NodeMCU device with the localhost server. I can establish a connection using the test.mosquitto.org server.
                      This is my required case: YouTube link
