    Can't connect NodeMCU with MQTT
    3431
      salmanfaris @sivanath last edited by
      @sivanath Does the local pub and sub is working over CLI?
        sivanath @salmanfaris last edited by
        @salmanfaris It was working in CLI, but now it's showing multiple usages at the portmultiple usage.png
        swalahamani 1 Reply Last reply Reply Quote 0
          swalahamani @sivanath last edited by swalahamani
          @sivanath
          It looks like mosquitto is trying to register both IPv4 and IPv6 on the same port.
          If IPv6 is not required for the application your use case, try changing the mosquitto.conf file as below for limiting it to ipv4:
          # Set to `ipv4` to force the listener to only use IPv4, or set to `ipv6` to
          # force the listener to only use IPv6. If you want support for both IPv4 and
          # IPv6, then do not use the socket_domain option.
          socket_domain ipv4
          Please please make sure the default port 1883 is not already in use by any other programs. If yes, you can either kill those programs (not recommended) or change the port in mosquitto.conf file:
          References: [1][2]
            sivanath @swalahamani last edited by sivanath
            @swalahamani @salmanfaris
            I changed my conf file and specified ipv4
            And this is the status of the port (from resource monitor):
            Image: mosquitto.exe
            PID: 3732
            Address: IPv6 loopback
            Protocol: TCP
            Port: 1883
            Firewall Status: Allowed, not restricted
            It is listening to mosquito..
              @sivanath
              Is it working now?
                  @sivanath
                  Did you follow the steps which I mentioned previously?
                    @swalahamani Yeah!!
                      @sivanath
                      Oh okay.
                      Please bring your device if you're coming for the upcoming MakerChat 0x13 tomorrow (IST). Either I and @salmanfaris or both of us will be there.
                      Or else we can set up a call sometime this weekend or the next week and sort it out.
                      Let me know.
                        @swalahamani I may not be able to come tomorrow. I think we could set up a call. How can I contact you personally?
