    Experience with SeeedStudio T1000 as tracker and data logger.
      Recently, I got a chance to work work the SeeedStudio T1000 tracker and I made a tracker and data logger with it. It comes with a LoRa module to transmit the data and has an inbuilt temperature and light sensor. The device is very easy to set up and get-started and I can say the experience of switching from different LoRa network servers is very pleasant and straightforward, same for the integration. I chose Ubidots to visualise the data captured.
      I also like the mobile application very much, it’s so easy to pair and change the tracker configuration on the go. I love it.
      I will experiment more and share my insights here. let me know if you want to know any specific details about the SenseCAP T1000.
      It’s live on Kickstarter and you can pledge for $29 for single T1000 tracker, you will get 1 piece T1000 with 3 months of free trial service on the SenseCAP platform. Take a look : https://www.kickstarter.com/projects/seeed/sensecap-t1000-track-what-you-care-with-no-boundaries
