    Error while uploading the program in to ESP32 -S3 sense
    • F
      Fasna C last edited by
      A serial exception error occurred: Write timeout
      Note: This error originates from pySerial. It is likely not a problem with esptool but ![alt text](image url)the hardware connection or drivers.
      For troubleshooting steps visit: https://docs.espressif.com/projects/esptool/en/latest/troubleshooting.html
      Failed uploading: uploading error: exit status 1
      • zainmuhammed
        zainmuhammed last edited by zainmuhammed
        I suggest to change the firmware. For this you can download the firmware from seeedstudio wiki https://files.seeedstudio.com/wiki/SeeedStudio-XIAO-ESP32S3/res/XIAOESP32S3-Sense-firmware.zip
        And use esptool to upload the firmware https://espressif.github.io/esptool-js/
        F 1 Reply Last reply Reply Quote 0
        • F
          Fasna C @zainmuhammed last edited by
          @zainmuhammed Thank you.
