    Need Help: Error compiling for board AI Thinker ESP32-CAM.
    ESP32
    3152
    • J
      jacob_jipson @salmanfaris last edited by
      Error log
      C:\Users\jacob\Documents\Arduino\libraries\jacobjipson-project-1_inferencing\src\edge-impulse-sdk\porting\espressif\ESP-NN\src\activation_functions\esp_nn_relu_s8_esp32s3.S: Assembler messages:
      C:\Users\jacob\Documents\Arduino\libraries\jacobjipson-project-1_inferencing\src\edge-impulse-sdk\porting\espressif\ESP-NN\src\activation_functions\esp_nn_relu_s8_esp32s3.S:35: Error: unknown opcode or format name 'ee.vldbc.8'
      C:\Users\jacob\Documents\Arduino\libraries\jacobjipson-project-1_inferencing\src\edge-impulse-sdk\porting\espressif\ESP-NN\src\activation_functions\esp_nn_relu_s8_esp32s3.S:39: Error: unknown opcode or format name 'ee.zero.q'
      C:\Users\jacob\Documents\Arduino\libraries\jacobjipson-project-1_inferencing\src\edge-impulse-sdk\porting\espressif\ESP-NN\src\activation_functions\esp_nn_relu_s8_esp32s3.S:42: Error: unknown opcode or format name 'ee.vld.128.ip'
      C:\Users\jacob\Documents\Arduino\libraries\jacobjipson-project-1_inferencing\src\edge-impulse-sdk\porting\espressif\ESP-NN\src\activation_functions\esp_nn_relu_s8_esp32s3.S:43: Error: unknown opcode or format name 'ee.vmax.s8'
      C:\Users\jacob\Documents\Arduino\libraries\jacobjipson-project-1_inferencing\src\edge-impulse-sdk\porting\espressif\ESP-NN\src\activation_functions\esp_nn_relu_s8_esp32s3.S:44: Error: unknown opcode or format name 'ee.vmin.s8'
      C:\Users\jacob\Documents\Arduino\libraries\jacobjipson-project-1_inferencing\src\edge-impulse-sdk\porting\espressif\ESP-NN\src\activation_functions\esp_nn_relu_s8_esp32s3.S:45: Error: unknown opcode or format name 'ee.vst.128.ip'
      C:\Users\jacob\Documents\Arduino\libraries\jacobjipson-project-1_inferencing\src\edge-impulse-sdk\porting\espressif\ESP-NN\src\activation_functions\esp_nn_relu_s8_esp32s3.S:58: Error: unknown opcode or format name 'ee.vld.l.64.ip'
      C:\Users\jacob\Documents\Arduino\libraries\jacobjipson-project-1_inferencing\src\edge-impulse-sdk\porting\espressif\ESP-NN\src\activation_functions\esp_nn_relu_s8_esp32s3.S:59: Error: unknown opcode or format name 'ee.vmax.s8'
      C:\Users\jacob\Documents\Arduino\libraries\jacobjipson-project-1_inferencing\src\edge-impulse-sdk\porting\espressif\ESP-NN\src\activation_functions\esp_nn_relu_s8_esp32s3.S:60: Error: unknown opcode or format name 'ee.vmin.s8'
      C:\Users\jacob\Documents\Arduino\libraries\jacobjipson-project-1_inferencing\src\edge-impulse-sdk\porting\espressif\ESP-NN\src\activation_functions\esp_nn_relu_s8_esp32s3.S:61: Error: unknown opcode or format name 'ee.vst.l.64.ip'
      C:\Users\jacob\Documents\Arduino\libraries\jacobjipson-project-1_inferencing\src\edge-impulse-sdk\porting\espressif\ESP-NN\src\activation_functions\esp_nn_relu_s8_esp32s3.S:98: Error: unknown opcode or format name 'ee.zero.q'
      C:\Users\jacob\Documents\Arduino\libraries\jacobjipson-project-1_inferencing\src\edge-impulse-sdk\porting\espressif\ESP-NN\src\activation_functions\esp_nn_relu_s8_esp32s3.S:40: Error: invalid empty loop
      C:\Users\jacob\Documents\Arduino\libraries\jacobjipson-project-1_inferencing\src\edge-impulse-sdk\porting\espressif\ESP-NN\src\activation_functions\esp_nn_relu_s8_esp32s3.S:56: Error: invalid empty loop
      C:\Users\jacob\Documents\Arduino\libraries\jacobjipson-project-1_inferencing\src\edge-impulse-sdk\porting\espressif\ESP-NN\src\activation_functions\esp_nn_relu_s8_esp32s3.S:40: Internal error in istack_push_space at /builds/idf/crosstool-NG/.build/HOST-i686-w64-mingw32/xtensa-esp32-elf/src/binutils/gas/config/tc-xtensa.c:12515.
      Please report this bug.
      Tool section
        salmanfaris @jacob_jipson last edited by
        @jacob_jipson said in Need Help: Error compiling for board AI Thinker ESP32-CAM.:
        ESP-NN
        Did you replace the NN folder in the lib as we do for XIAO esp32? and for the AI Thinker ESP32-CAM, you don't need to do that.
        now, try to delete the library and re-add a new one and compile.
        J 1 Reply Last reply Reply Quote 1
        • J
          @salmanfaris The problem was resolved. Thankyou so much.
            @jacob_jipson Glad to hear that. 🙌
              mahesh02 last edited by
              Im having the same error as below, it will be really awesome if you can help me.
              In file included from C:\Users\Mahesh\OneDrive\Documents\Arduino\libraries\mahesh02-project-1_inferencing\src/edge-impulse-sdk/classifier/ei_classifier_types.h:40,
              from C:\Users\Mahesh\OneDrive\Documents\Arduino\libraries\mahesh02-project-1_inferencing\src/edge-impulse-sdk/classifier/ei_model_types.h:40,
              from C:\Users\Mahesh\OneDrive\Documents\Arduino\libraries\mahesh02-project-1_inferencing\src/edge-impulse-sdk/classifier/ei_run_classifier.h:38,
              from C:\Users\Mahesh\OneDrive\Documents\Arduino\libraries\mahesh02-project-1_inferencing\src/mahesh02-project-1_inferencing.h:49,
              from C:\Users\Mahesh\AppData\Local\Temp\arduino_modified_sketch_680639\esp32_camera.ino:27:
              C:\Users\Mahesh\OneDrive\Documents\Arduino\libraries\mahesh02-project-1_inferencing\src/model-parameters/model_metadata.h:108:2: warning: #warning 'EI_CLASSFIER_OBJECT_DETECTION_COUNT' is used for the guaranteed minimum number of objects detected. To get all objects during inference use 'bounding_boxes_count' from the 'ei_impulse_result_t' struct instead. [-Wcpp]
              In file included from C:\Users\Mahesh\OneDrive\Documents\Arduino\libraries\mahesh02-project-1_inferencing\src/edge-impulse-sdk/dsp/memory.hpp:38,
              from C:\Users\Mahesh\OneDrive\Documents\Arduino\libraries\mahesh02-project-1_inferencing\src/edge-impulse-sdk/dsp/ei_alloc.h:34,
              from C:\Users\Mahesh\OneDrive\Documents\Arduino\libraries\mahesh02-project-1_inferencing\src/edge-impulse-sdk/dsp/ei_vector.h:34,
              from C:\Users\Mahesh\OneDrive\Documents\Arduino\libraries\mahesh02-project-1_inferencing\src/edge-impulse-sdk/dsp/numpy_types.h:40,
              from C:\Users\Mahesh\OneDrive\Documents\Arduino\libraries\mahesh02-project-1_inferencing\src/edge-impulse-sdk/dsp/ei_dsp_handle.h:35,
              from C:\Users\Mahesh\OneDrive\Documents\Arduino\libraries\mahesh02-project-1_inferencing\src/edge-impulse-sdk/classifier/ei_model_types.h:41,
              c:\users\mahesh\onedrive\documents\arduino\libraries\mahesh02-project-1_inferencing\src\edge-impulse-sdk\porting\ei_classifier_porting.h:310: warning: "EI_PORTING_ARDUINO" redefined
              #define EI_PORTING_ARDUINO 0
              c:\users\mahesh\onedrive\documents\arduino\libraries\mahesh02-project-1_inferencing\src\edge-impulse-sdk\porting\ei_classifier_porting.h:279: note: this is the location of the previous definition
              #define EI_PORTING_ARDUINO 1
              In file included from C:\Users\Mahesh\OneDrive\Documents\Arduino\libraries\mahesh02-project-1_inferencing\src/edge-impulse-sdk/dsp/speechpy/speechpy.hpp:35,
              from C:\Users\Mahesh\OneDrive\Documents\Arduino\libraries\mahesh02-project-1_inferencing\src/edge-impulse-sdk/classifier/ei_run_dsp.h:40,
              from C:\Users\Mahesh\OneDrive\Documents\Arduino\libraries\mahesh02-project-1_inferencing\src/edge-impulse-sdk/classifier/ei_run_classifier.h:41,
              C:\Users\Mahesh\OneDrive\Documents\Arduino\libraries\mahesh02-project-1_inferencing\src/edge-impulse-sdk/dsp/speechpy/feature.hpp: In static member function 'static int ei::speechpy::feature::mfe(ei::matrix_t*, ei::matrix_t*, ei::signal_t*, uint32_t, float, float, uint16_t, uint16_t, uint32_t, uint32_t, uint16_t)':
              C:\Users\Mahesh\OneDrive\Documents\Arduino\libraries\mahesh02-project-1_inferencing\src/edge-impulse-sdk/dsp/speechpy/feature.hpp:236:52: warning: missing initializer for member 'ei::speechpy::ei_stack_frames_info::frame_ixs' [-Wmissing-field-initializers]
              stack_frames_info_t stack_frame_info = { 0 };
              C:\Users\Mahesh\OneDrive\Documents\Arduino\libraries\mahesh02-project-1_inferencing\src/edge-impulse-sdk/dsp/speechpy/feature.hpp:236:52: warning: missing initializer for member 'ei::speechpy::ei_stack_frames_info::frame_length' [-Wmissing-field-initializers]
              C:\Users\Mahesh\OneDrive\Documents\Arduino\libraries\mahesh02-project-1_inferencing\src/edge-impulse-sdk/dsp/speechpy/feature.hpp: In static member function 'static int ei::speechpy::feature::mfe_v3(ei::matrix_t*, ei::matrix_t*, ei::signal_t*, uint32_t, float, float, uint16_t, uint16_t, uint32_t, uint32_t, uint16_t)':
              C:\Users\Mahesh\OneDrive\Documents\Arduino\libraries\mahesh02-project-1_inferencing\src/edge-impulse-sdk/dsp/speechpy/feature.hpp:436:52: warning: missing initializer for member 'ei::speechpy::ei_stack_frames_info::frame_ixs' [-Wmissing-field-initializers]
              C:\Users\Mahesh\OneDrive\Documents\Arduino\libraries\mahesh02-project-1_inferencing\src/edge-impulse-sdk/dsp/speechpy/feature.hpp:436:52: warning: missing initializer for member 'ei::speechpy::ei_stack_frames_info::frame_length' [-Wmissing-field-initializers]
              C:\Users\Mahesh\OneDrive\Documents\Arduino\libraries\mahesh02-project-1_inferencing\src/edge-impulse-sdk/dsp/speechpy/feature.hpp: In static member function 'static int ei::speechpy::feature::spectrogram(ei::matrix_t*, ei::signal_t*, float, float, float, uint16_t, uint16_t)':
              C:\Users\Mahesh\OneDrive\Documents\Arduino\libraries\mahesh02-project-1_inferencing\src/edge-impulse-sdk/dsp/speechpy/feature.hpp:576:52: warning: missing initializer for member 'ei::speechpy::ei_stack_frames_info::frame_ixs' [-Wmissing-field-initializers]
              C:\Users\Mahesh\OneDrive\Documents\Arduino\libraries\mahesh02-project-1_inferencing\src/edge-impulse-sdk/dsp/speechpy/feature.hpp:576:52: warning: missing initializer for member 'ei::speechpy::ei_stack_frames_info::frame_length' [-Wmissing-field-initializers]
              In file included from C:\Users\Mahesh\OneDrive\Documents\Arduino\libraries\mahesh02-project-1_inferencing\src/mahesh02-project-1_inferencing.h:49,
              C:\Users\Mahesh\OneDrive\Documents\Arduino\libraries\mahesh02-project-1_inferencing\src/edge-impulse-sdk/classifier/ei_run_classifier.h: In function 'EI_IMPULSE_ERROR {anonymous}::process_impulse(ei_impulse_handle_t*, ei::signal_t*, ei_impulse_result_t*, bool)':
              C:\Users\Mahesh\OneDrive\Documents\Arduino\libraries\mahesh02-project-1_inferencing\src/edge-impulse-sdk/classifier/ei_run_classifier.h:307:23: error: format '%lu' expects argument of type 'long unsigned int', but argument 2 has type 'size_t' {aka 'unsigned int'} [-Werror=format=]
              ei_printf("ERR: Out of memory, can't allocate matrix_ptrs[%lu]\n", ix);
              C:\Users\Mahesh\OneDrive\Documents\Arduino\libraries\mahesh02-project-1_inferencing\src/edge-impulse-sdk/classifier/ei_run_classifier.h:312:23: error: format '%lu' expects argument of type 'long unsigned int', but argument 2 has type 'size_t' {aka 'unsigned int'} [-Werror=format=]
              C:\Users\Mahesh\OneDrive\Documents\Arduino\libraries\mahesh02-project-1_inferencing\src/edge-impulse-sdk/classifier/ei_run_classifier.h: In function 'EI_IMPULSE_ERROR {anonymous}::process_impulse_continuous(ei_impulse_handle_t*, ei::signal_t*, ei_impulse_result_t*, bool)':
              C:\Users\Mahesh\OneDrive\Documents\Arduino\libraries\mahesh02-project-1_inferencing\src/edge-impulse-sdk/classifier/ei_run_classifier.h:558:27: error: format '%lu' expects argument of type 'long unsigned int', but argument 2 has type 'size_t' {aka 'unsigned int'} [-Werror=format=]
              C:\Users\Mahesh\OneDrive\Documents\Arduino\libraries\mahesh02-project-1_inferencing\src/edge-impulse-sdk/classifier/ei_run_classifier.h:563:27: error: format '%lu' expects argument of type 'long unsigned int', but argument 2 has type 'size_t' {aka 'unsigned int'} [-Werror=format=]
              C:\Users\Mahesh\AppData\Local\Temp\arduino_modified_sketch_680639\esp32_camera.ino: In function 'void loop()':
              C:\Users\Mahesh\AppData\Local\Temp\arduino_modified_sketch_680639\esp32_camera.ino:181:38: warning: missing initializer for member 'ei_impulse_result_t::bounding_boxes_count' [-Wmissing-field-initializers]
              ei_impulse_result_t result = { 0 };
              C:\Users\Mahesh\AppData\Local\Temp\arduino_modified_sketch_680639\esp32_camera.ino:181:38: warning: missing initializer for member 'ei_impulse_result_t::classification' [-Wmissing-field-initializers]
              C:\Users\Mahesh\AppData\Local\Temp\arduino_modified_sketch_680639\esp32_camera.ino:181:38: warning: missing initializer for member 'ei_impulse_result_t::anomaly' [-Wmissing-field-initializers]
              C:\Users\Mahesh\AppData\Local\Temp\arduino_modified_sketch_680639\esp32_camera.ino:181:38: warning: missing initializer for member 'ei_impulse_result_t::timing' [-Wmissing-field-initializers]
              C:\Users\Mahesh\AppData\Local\Temp\arduino_modified_sketch_680639\esp32_camera.ino:181:38: warning: missing initializer for member 'ei_impulse_result_t::copy_output' [-Wmissing-field-initializers]
              C:\Users\Mahesh\AppData\Local\Temp\arduino_modified_sketch_680639\esp32_camera.ino:181:38: warning: missing initializer for member 'ei_impulse_result_t::postprocessed_output' [-Wmissing-field-initializers]
              cc1plus.exe: some warnings being treated as errors
              Using library mahesh02-project-1_inferencing at version 1.0.1 in folder: C:\Users\Mahesh\OneDrive\Documents\Arduino\libraries\mahesh02-project-1_inferencing
                salmanfaris @mahesh02 last edited by
                @mahesh02 From the current Arduino ESP32 board files, we don't need to install the ESP-NN separately.
                But try to choose the esp32 board version 3.1.3 and check, as I also faced issues with the latest esp32 board file.
                • @mahesh02 From the current Arduino ESP32 board files, we don't need to install the ESP-NN separately.
                • This also happened to me when I was given a task from my company, So what I can recommend is:
                  Ensure that the correct board, "AI Thinker ESP32-CAM," is selected in the Tools menu of your Arduino IDE.
                  If the board is not listed, you may need to install it through the Board Manager. Search for "ESP32" and install the latest version.
                  Ensure that necessary libraries like ESP32-CAM, WiFi, and HTTPClient are installed. You can install them through the Library Manager.
                  Carefully check your code for typos, missing semicolons, or incorrect syntax.
                  Verify that you're using the correct function names and parameters.
                • Hi @PumpedMedusa, The rage is depends on the Antenna and how much TX power you have.
                  To choose antenna, first you need figure out - where your nodes will be, take a look at the below image. The antenna act like a "torch" if you have more dbi that mean it's focus will be increase and it can reach more distance but the angle it have it less, like a laser.
                  also, obstacle such as buildings, tress and mountains will affect the signal and deplete it.
                  So, answer for you question - What is the best LoRa module to use for long distance network? - It's really depends on where you planning to put the nodes and how high you putting the gateway. Let me know know your thoughts.
                • @Parves-DOMINO Did you able to solve the issue?
