    How to perform stability analysis of a drone?
    • zainmuhammed
      zainmuhammed last edited by
      Specifically how to find the yaw rate pitch rate and roll rate for a drone.
        salmanfaris @zainmuhammed last edited by
        @zainmuhammed Curious to know, What kind of drone are you building and what kind of material are you using?
        zainmuhammed 1 Reply Last reply Reply Quote 0
        • zainmuhammed
          zainmuhammed @salmanfaris last edited by
          @salmanfaris I'm building a payload-releasing drone under 2kg (micro class). and the entire structure builds using carbon fiber and ABS plastic.
            @zainmuhammed Oh that's cool. Let me also take a look at the stability analysis of a drone and get back to you.
