    The New Particle Photon 2 - Powered by Realtek RTL8721DM MCU
    Development Boards
      The particle release draft of Photon 2 is a development module with a microcontroller and Wi-Fi networking. The form factor is similar to the Argon (Adafruit Feather), but the Photon 2 supports 2.4 GHz and 5 GHz Wi-Fi, BLE, and has much larger RAM and flash that can support larger applications.
      It is intended to replace both the Photon and Argon modules. It contains the same module as the P2, making it easier to migrate from a pin-based development module to a SMD mass-production module if desired.
      Features
      • 802.11a/b/g/n Wi-Fi, 2.4 GHz and 5 GHz
      • Integrated PCB antenna
      • Integrated U.FL connector for external antenna
      • Integrated RF switch
      • BLE 5 using same antenna as Wi-Fi
      • Realtek RTL8721DM MCU
      • ARM Cortex M33 CPU, 200 MHz
      • 2048 KB (2 MB) user application maximum size
      • 3072 KB (3 MB) of RAM available to user applications
      • 2 MB flash file system
      • FCC, IC, and CE certified
      Source: https://docs.particle.io/reference/datasheets/wi-fi/photon-2-datasheet/
      • saheen_palayi
        saheen_palayi last edited by
        Interesting...
        is it available in our Indian market?
          salmanfaris @saheen_palayi last edited by
          @saheen_palayi Not yet, It's their first draft for the Photon 2 . No information on ETA or available countries.
            salmanfaris @salmanfaris last edited by
            @saheen_palayi Photon2 is now available at $ 17.95 on their official store page, soon it will be available on the Indian website. I was able to grab it once and will ping you once I received it.
            • @Vishnuraj2003 Are you able to fix it?
            • Hi @Vishnuraj2003 ,
              As per the documentation, I think we only route the data over the LoRa oR BT. The Wifi is used for sniffing access points for better geo-location and positioning along with GPS.
              And what is the issue you facing when connecting the tracker with gateway? Double check the FREQ on both node and gateway configuration
            • I'm working with Seeed Studio's Wio Tracker 1110 Dev Board. According to Seeed Studio's documentation, we can use the Wi-Fi antenna inside the Wio Tracker to send data. However, when I used the Sensecraft app, it shows that the board is offline. I have tried connecting it to the Sensecap M2 Gateway but couldn't do it due to a lack of documentation. Please share any advice or resources that could help. Thank you.
            • @binishmatheww All the best. Let us know if you need any help.
            • @salmanfaris thanks a lot. 👍😁
