    showing the below mentioned error when i installing node red
    • mkgrmAbhinand
      mkgrmAbhinand last edited by
        salmanfaris @mkgrmAbhinand last edited by
        @mkgrmabhinand Hi, It Looks like you didn't install the NodeJS on your computer, or didn't add the PATH correctly in the environment variables.
        Could you confirm that you installed the Node JS in your computer from the .exe or .msi installation files?
        If not and if you want to run Node-RED, you need to install recommended NodeJS version 14.x and you can download the version here .
        swalahamani 1 Reply Last reply Reply Quote 1
        • swalahamani
          swalahamani @salmanfaris last edited by
          Hi @mkgrmAbhinand ,
          Did your issue resolve?
