    NMCLI AP Mode config error | Connection activation failed: No suitable device found for this connection | Raspberry Pi 3 Model B Rev 1.2
      rafitc99 last edited by
      I was trying to configure AP mode in Raspberrypi by using Network Manager. I'm using the below script. but it is throwing some errors.
      Bash Script to set AP Mode
      host="MyRPiAPMode"
      sudo nmcli con add type wifi ifname wlan0 con-name $host autoconnect yes ssid $host
      sudo nmcli con modify $host 802-11-wireless.mode ap 802-11-wireless.band bg ipv4.method shared
      sudo nmcli con modify $host wifi-sec.key-mgmt wpa-psk
      sudo nmcli con modify $host wifi-sec.psk "SomeRandomPassword"
      sudo nmcli radio wifi on
      sudo nmcli con up $host
      Error ----
      Connection 'MyRPiAPMode' (60965f2a-f510-48ef-afaf-0864242d0c06) successfully added.
      Error: Connection activation failed: No suitable device found for this connection (device eth0 not available because profile is not compatible with device (mismatching interface name)).
      nmcli con (After script execution)
      NAME                UUID                                  TYPE      DEVICE
      Wired connection 1  9589ff1a-9923-3de3-a8a4-90b319661878  ethernet  eth0
      MyRPiAPMode         60965f2a-f510-48ef-afaf-0864242d0c06  wifi      --
      nmcli dev
      DEVICE  TYPE      STATE        CONNECTION
      eth0    ethernet  connected    Wired connection 1
      wlan0   wifi      unavailable  --
      lo      loopback  unmanaged    --
      I tried to make it availble via sudo nmcli radio wifi on
      But not working.
      this is the log
      -- Journal begins at Sat 2021-08-07 09:28:21 IST. --
      Aug 10 15:06:19 NWPI-b5b072 NetworkManager[16140]: <info>  [1660124179.9816] audit: op="connection-update" uuid="60965f2a-f510-48ef-afaf-0864242d0c06" name="MyRPiAPMode" args="802-11-wireless-security.psk" pid=25120 uid=0 result="success"
      Aug 10 15:06:20 NWPI-b5b072 NetworkManager[16140]: <info>  [1660124180.0902] audit: op="radio-control" arg="wireless-enabled" pid=25125 uid=0 result="success"
      Aug 10 15:06:21 NWPI-b5b072 NetworkManager[16140]: <info>  [1660124181.4241] agent-manager: agent[641f99ab55d9691c,:1.692/nmcli-connect/0]: agent registered
      Aug 10 15:06:21 NWPI-b5b072 NetworkManager[16140]: <info>  [1660124181.4281] audit: op="connection-activate" uuid="60965f2a-f510-48ef-afaf-0864242d0c06" name="MyRPiAPMode" result="fail" reason="No suitable device found for this connection (device eth0 not available because profile is not compatible with device (mismatching interface name))."
      Aug 10 15:06:52 NWPI-b5b072 NetworkManager[16140]: <info>  [1660124212.0573] agent-manager: agent[70ee130ba0f26cd7,:1.696/nmcli-connect/1000]: agent registered
      Aug 10 15:06:52 NWPI-b5b072 NetworkManager[16140]: <info>  [1660124212.0614] audit: op="connection-activate" uuid="60965f2a-f510-48ef-afaf-0864242d0c06" name="MyRPiAPMode" result="fail" reason="No suitable device found for this connection (device eth0 not available because profile is not compatible with device (mismatching interface name))."
      Aug 10 15:07:23 NWPI-b5b072 NetworkManager[16140]: <info>  [1660124243.0370] agent-manager: agent[cc77ef461499c164,:1.700/nmcli-connect/0]: agent registered
      Aug 10 15:07:23 NWPI-b5b072 NetworkManager[16140]: <info>  [1660124243.0414] audit: op="connection-activate" uuid="60965f2a-f510-48ef-afaf-0864242d0c06" name="MyRPiAPMode" result="fail" reason="No suitable device found for this connection (device eth0 not available because profile is not compatible with device (mismatching interface name))."
      Aug 10 15:07:41 NWPI-b5b072 NetworkManager[16140]: <info>  [1660124261.8406] agent-manager: agent[79b01af218789b42,:1.702/nmcli-connect/0]: agent registered
      Aug 10 15:07:41 NWPI-b5b072 NetworkManager[16140]: <info>  [1660124261.8446] audit: op="connection-activate" uuid="60965f2a-f510-48ef-afaf-0864242d0c06" name="MyRPiAPMode" result="fail" reason="No suitable device found for this connection (device eth0 not available because profile is not compatible with device (mismatching interface name))."
        salmanfaris @rafitc99 last edited by
        @rafitc99 said in NMCLI AP Mode config error | Connection activation failed: No suitable device found for this connection | Raspberry Pi 3 Model B Rev 1.2:
        host="MyRPiAPMode"
        Hi @rafitc99, Are you able to set up the AP when trying the commands individually?
        swalahamani 1 Reply Last reply Reply Quote 0
        • swalahamani
          swalahamani @salmanfaris last edited by
          Hey @rafitc99 ,
