    ESP8266 Restart while running ISR. [ESP8266 FreeRTOS SDK]
      rafitc99 last edited by
      I'm trying to pass a value into Queue from Interrupt Service Routine(ISR) using xQueueSendFromISR() <-- Reference
      But I'm getting this error and ESP restart immediately.
      Guru Meditation Error: Core  0 panic'ed (LoadProhibited). Exception was unhandled.
      Core 0 register dump:
      PC      : 0x4021227c  PS      : 0x00000033  A0      : 0x4021c72e  A1      : 0x3ffe8220
      Here is the gpio interrupt example which I'm following.
      Here is my code. I did some modification in this.
      Check 70th line of this location.
      static void main_power_isr_handler(void* arg)
          xQueueHandle* main_q = (xQueueHandle*)arg;
          static main_q_payload_t msg;
          msg.hdr = E_MAIN_MSG_MAIN_POWER_STATUS;
          msg.bool_payload = gpio_get_level(GPIO_MAIN_POWER);
          //ets_printf("Someone Interrupted \n ");
          xQueueSendFromISR(main_q, &msg, NULL); //!!! THIS LINE
      rafitc99 1 Reply Last reply Reply Quote 1
        rafitc99 @rafitc99 last edited by
        Update!!
        I found the issue
        I created a Queue inside Rgpio.cpp and called a Funciton from main.cpp to check data in Queue. That worked well!!
        Reference to the #commit .
        rafitc99 1 Reply Last reply Reply Quote 2
          rafitc99 @rafitc99 last edited by rafitc99
          BaseType_t xQueueSendFromISR
                         QueueHandle_t xQueue,
                         const void *pvItemToQueue,
                         BaseType_t *pxHigherPriorityTaskWoken
          I was trying to pass a pointer. That was the issue.
          Reference
          salmanfaris 1 Reply Last reply Reply Quote 2
            salmanfaris @rafitc99 last edited by
            Thanks for sharing @rafitc99 . Glad to know that it was solved.
