    How the Colossal of the Social Media went disappeared from Internet Last Night?
    • swalahamani
      swalahamani last edited by
      Curious to know how the social media giant went down for an unusual time?
      Read this article by Cloudflare explaining how complex the internals of the Internet is and what happened to Facebook and its affiliated services.
      https://canal.swalah.co/howfbdown
      #facebookdown #WhatsAppDown #Instagramdown #socialmedia
