    Android programming using ECLIPSE Ide & android sdk
    • Bazil NIzam
      Bazil NIzam last edited by
      I have been facing this problem recently while I run the program the output terminal just shows scanned text and the android virtual device is not opening. I have reinstalled the SDK but the problem still persist.!9e6e2081-4f83-428c-b733-456b84ffa933-image.png
      Bazil Nizam
      Front-End Web Dev, UI/Ux Designer
      +91 9895 094 299
      bazil4u@gmail.com
      twitter.com/BazilNIzam
      swalahamani 1 Reply Last reply Reply Quote 0
      • swalahamani
        swalahamani @Bazil NIzam last edited by
        @bazil-nizam
        Developing Android Applications with Eclipse is a bit old way. Few eclipse enthusiasts might be doing it still though. For your issue, check all the environment variables related to SDK and Emulators are correctly configured.
        If you're a beginner and no specific reason to use Eclipse, try to start with AndroidStudio.
