    SIM800L is not working after disconnecting with PC
    3547
      rafitc99 @salmanfaris last edited by
      @salmanfaris At that time not receiving an actual message. Receiving a blank message.
        salmanfaris @rafitc99 last edited by
        @rafitc99 When powering SIM800L through DC-DC buck alone it's sending a message right?
          @salmanfaris When connecting with PC. It will work well.
            @rafitc99 when powering with the LM2596 it's not sending message text right? but sending blank SMS right?
              @salmanfaris Yes.
                Ok, then you need to check the LM2596 output current and voltage!
                  Thank-you @salmanfaris
                  It's solved.
                  Actually, It was my mistake. I didn't add a proper reset for MCU.
