    A reliable right angled THT connector for PCB
    • Mennyt
      Mennyt last edited by
      which type of THT connector will be suitable for a right angeled connection in PCB and would be easily available.
      kowshik1729 1 Reply Last reply Reply Quote 0
        kowshik1729 @Mennyt last edited by kowshik1729
        @Mennyt The general right angled header pins are the cheapest option. Something like this https://robu.in/product/2-54mm-2x20-right-angle-male-header-strip-pack-of-2/?gclid=CjwKCAiA4o79BRBvEiwAjteoYDcmnOSwTUviMZzRBeHz_aENF_fQgj3BrKXAzYs6GIHknHSOJ4_2KhoC1fAQAvD_BwE
