    Need Chlorine level sensor
      Hi guys,
      Hope everyone are doing well. Does anyone here know any sensor that can detect the level of chlorine in the air. Please let me know if any?
        I found some sensor for Chlorine measurement of the free chlorine concentration generated from inorganic sources, you can find the details here Type 8232 - Chlorine Sensor
          @salmanfaris Thanks for the reply. This doesn't seem to be interfaceable with Arduino.
            salmanfaris @kowshik1729 last edited by salmanfaris
            @kowshik1729 You can find the sensor Operating Instructions here. since it's an industrial one, Arduino instruction will not available out of the box! but we can contact the manufacture regarding the communication protocols to write driver/ interfacing programme fo this.
