    Is there any good resource for learning Verilog and FPGA Implementation? Also I'd like some suggestions for learning Digital Logic Design.
    • V
      vinodcm last edited by
      I'm starting with a project now and I'm in requirements of these topics.Please help me.
        Hi @vinodcm, there is some good resource on FPGA and HDL devices and development in general on Awesome FPGA GitHub repo, Awesome HDL and Hardware development using HDL please check.
        • V
          Thanks! I'll check them out.
