    Autodesk Eagle Library for Espressif ESP32-PICO-D4 (QFN49 LF77)
    • Suhailjr
      Suhailjr last edited by
      I was tried searching the eagle library for ESP32-PICO-32 for designing an ESP32 based project. But unfortunately, i couldn't find the best one that i could use in my design. So i made the Eagle library for ESP32-PICO-D4 and used it in my design. Here i posted the link to the library file. Enjoy your PCB designing!
      Eagle library is now uploaded to my GitHub account: https://github.com/suhail-jr/Autodesk-Eagle-library/blob/master/ESP32-PICO-D4.lbr
        Thanks for sharing 😍 , are you planning any project on that. @kowshik1729 check this out.
          @salmanfaris Thanks for tagging me. I have already designed a PCB with ESP32 PICO D4 which is the new MCU series from espressif. @Suhailjr I have found the footprint very easily from snapEDA. Here it is
          https://www.snapeda.com/parts/ESP32-PICO-D4/Espressif Systems/view-part/?ref=search&t=ESP32 PICO D4
          Anyways the one you made is very nice too. Awesome, thanks for sharing
          • Suhailjr
            Suhailjr last edited by salmanfaris
            @kowshik1729 @salmanfaris thank you!
            kowshik I was using that earlier but the symbol design looks bigger to me and the symbol i designed is exactly looks like Limon Fried's eagle library but unfortunately, she has not shared it yet. @salmanfaris i am planning to build a dev board using esp32 pico d4 with multiple built-in features!
              salmanfaris @Suhailjr last edited by
              @Suhailjr That sounds cool, keep us updated 😊
                @Suhailjr That's cool. Let us know about the board when you start it. 🙂
