    Autodesk Eagle Library for Espressif ESP32-PICO-D4 (QFN49 LF77)
      Thanks for sharing 😍 , are you planning any project on that. @kowshik1729 check this out.
        @salmanfaris Thanks for tagging me. I have already designed a PCB with ESP32 PICO D4 which is the new MCU series from espressif. @Suhailjr I have found the footprint very easily from snapEDA. Here it is
        https://www.snapeda.com/parts/ESP32-PICO-D4/Espressif Systems/view-part/?ref=search&t=ESP32 PICO D4
        Anyways the one you made is very nice too. Awesome, thanks for sharing
        • Suhailjr
          Suhailjr last edited by salmanfaris
          @kowshik1729 @salmanfaris thank you!
          kowshik I was using that earlier but the symbol design looks bigger to me and the symbol i designed is exactly looks like Limon Fried's eagle library but unfortunately, she has not shared it yet. @salmanfaris i am planning to build a dev board using esp32 pico d4 with multiple built-in features!
            salmanfaris @Suhailjr last edited by
            @Suhailjr That sounds cool, keep us updated 😊
              @Suhailjr That's cool. Let us know about the board when you start it. 🙂
