    SIM800L is not working after disconnecting with PC
    3962
      rafitc99 last edited by rafitc99
      This is my messy code.
      #include <SoftwareSerial.h>
      //#include <avr/wdt.h>
      //Create software serial object to communicate with SIM800L
      SoftwareSerial mySerial(9, 2); //SIM800L Tx & Rx is connected to Arduino #3 & #2
      String content = "";
      int Pulses = 3; //connect water flow sensor
      volatile int pulsecount; //Variable to count number of pulses
      unsigned long curr, prev, interval = 5000;
      int led = 11;
      long count = 0;
      unsigned long onCall_prev_time, onCall_interval = 15000;
      unsigned long timer;
      bool ledFlag = 0;
      bool smsFlag = 0; // sms flag
      bool ackFlag = 0; //acknowledge flag
      bool ackFlag_1 = 0; //acknowledge flag
      bool recSmsFlag = 0; //Receive SmS flag
      int statusAck = 0;
      bool onCall_flag = 0; //to check call status
      int c = 0;
      bool terminate_flag = 0; //Flag to terminate whole event
      bool terminate_flag_1 = 0; //Flag to terminate whole event
      String number_1 = "YYxxxxxxxxxx";
        String number_2 = "YYxxxxxxxxxx";
        String number_3 = "YYxxxxxxxxxx";
        String number_4 = "YYxxxxxxxxxx";
        String test = "YYxxxxxxxxxx";
        String userName;
        pinMode(led, OUTPUT);
        pinMode(Pulses, INPUT_PULLUP);
        attachInterrupt(digitalPinToInterrupt(Pulses), CountPulses, FALLING);
        //Begin serial communication with Arduino and Arduino IDE (Serial Monitor)
        //Begin serial communication with Arduino and SIM800L
        mySerial.begin(9600);
        Serial.println("Initializing...");
        delay(500);
        Serial.println("Watchdog Enabled ");
        mySerial.println("AT+IPR=9600");
        updateSerial();
        //wdt_enable(WDTO_8S);
      void updateSerial()
        //wdt_reset();
        detachInterrupt(CountPulses);
        delay(500);
        while (Serial.available())
          mySerial.write(Serial.read());//Forward what Serial received to Software Serial Port
        while (mySerial.available())
          Serial.write(mySerial.read());//Forward what Software Serial received to Serial Port
      void recSerial()
        String msg;
        delay(500);
          msg = mySerial.readString();//Forward what Software Serial received to Serial Port
          processMsg(msg);
        //wdt_reset();
        Serial.println("Loop strated----++++---++");
        pulsecount = 0;  //Start counting from 0 again
        interrupts();    //Enables interrupt on arduino pin 3
        delay(1000);
        //Calculating the water flow rate in Milli Liters per minute
        long flowRate;
        flowRate = (pulsecount * 2.22 * 60);
        Serial.print("Flow rate=");
        Serial.print(flowRate);   //Print milli liters per minute on serial monitor
        Serial.println("mL/minute");
        recSerial();
        digitalWrite(led, ledFlag); //Set or reset led based on the flow
        if (ackFlag_1) {
          Serial.println("Acknowledge Received-----------------------");
          content = "ACK received from " + userName +" paused all notifications ";
          smsSend_5(content);
          ackFlag_1 = false;
        if (terminate_flag_1) {
          content = "GOT 'TERMINATE' From "+userName;
          smsSend_5(content);
          terminate_flag_1 = false;
        if (onCall_flag) {
          Serial.println(c++);
          if (c >= 15) {
            Serial.println("Calling Event Completed");
            mySerial.println("ATH");
            updateSerial();
            onCall_flag = false;
            c = 0;
        if (statusAck) {
          if (pulsecount != 0) {
            smsSend_5("No problem. it's working perfectly!");
            statusAck = 0;
          else if (pulsecount == 0) {
            smsSend_5("It's Not working!!!!");
            statusAck = 0;
        if (!recSmsFlag) {
          Serial.println("Setting into Receive Mode");
          recMode();
          recSmsFlag = true;
        if (flowRate > 1) {
          Serial.println("Reseted all countors for new event ---++");
          count = 0; //Reset countor
          prev = 0; //reset timer;
          ackFlag = false; //reset ACK flags
          smsFlag = false; //Sent sms flag
          terminate_flag = false; //Reset Terminate flag
          ledFlag = 1; //Set LED Flag
        if (flowRate == 0.00) {
          curr = millis();
          Serial.println("flowrate is Zero!!");
          ledFlag = 0; //Reset flag
          //wdt_reset();
          Serial.println("Reseted Watchdog");
          if (curr - prev >= 1000) {
            prev = curr;
            Serial.print(count++);
            Serial.println(" Seconds");
            if (count == 30 && ackFlag == 0) {
              Serial.println("ALERT 1 - FLow not working for 30 Seconds");
              //ackFlag = 0;
              smsSend_5("Flow is Zero about 30 Seconds!!!");
              smsFlag = true; //set sms flag
              //Send To other number too!
              //wdt_reset();
              //Send SMS
            if (count == 40 && ackFlag == 0) {
              Serial.println("ALERT 1 - FLow not working for 40 Seconds");
              //ackFlag = 0;
              //smsSend_5("Flow is Zero about 40 Seconds!!!");
              //wdt_reset();
              makeCall(test);
              onCall_flag = 1;
              //Send SMS
            if (count == 50 && ackFlag == 0) {
              Serial.println("ALERT 1 - FLow not working for 50 Seconds");
              //ackFlag = 0;
              //wdt_reset();
              //Send SMS
            if (count == 60 && ackFlag == 0) {
              Serial.println("ALERT 1 - FLow not working for 60 Seconds");
              //ackFlag = 0;
              //wdt_reset();
              //Send SMS
            if (count == 90 && ackFlag == 0) {
              Serial.println("Not working for 1.5 minutes");
              makeCall(test);
              //smsSend();
              //SmS
              //wdt_reset();
            if (count == 150 && ackFlag == 0) {
              Serial.println("Not working for 2.5 minutes");
              //        makeCall(test); //make call to Number 2
              smsSend_5("Flow is Zero about 2.5 Minutes!!!");
              //smsSend(number_2,"Flow is Zero about 2.5 Minutes!!!");
              //smsSend(number_3,"Flow is Zero about 2.5 Minutes!!!");
              //smsSend(number_4,"Flow is Zero about 2.5 Minutes!!!");
              //SmS
              //wdt_reset();
            if (count == 210 && ackFlag == 0) {
              Serial.println("Not working for 3.5 minutes");
              smsSend_5("Flow is Zero about 3.5 Minutes!!!");
      //        makeCall(number_1); //make call to Number 3
              //smsSend();
              //wdt_reset();
              //SmS
            if (count == 270 && ackFlag == 0) {
              Serial.println("Not working for 4.5 minutes");
              smsSend_5("Flow is Zero about 4.5 Minutes!!!");
              //        makeCall(number_2); //make call to Number 4
              //smsSend();
              //SmS
            if (count == 180 && terminate_flag == 0) {
              Serial.println("just a reminder");
              smsSend_5("Blower is not working more than 8 minutes");
             // smsSend_5("It's been 8+ Minutes Your blower is not working.");
              //smsSend(number_3,"It's been 8+ Minutes Your blower is not working. Hope Now, You are working on that ;)");
              //smsSend(number_4,"It's been 8+ Minutes Your blower is not working. Hope Now, You are working on that ;)");
            if (count >= 600 && terminate_flag == 0) {
              Serial.println("DANGER!!!");
              smsSend_5("DANGER!! Flow is Not working more than 10 Minutes!!!");
              count = 0;
              ///SmS
      void CountPulses()
        pulsecount++; //Increment the variable on every pulse
      void recMode(){
        Serial.println("Setting Recieve mode");
        mySerial.println("AT");
        updateSerial();
        mySerial.println("AT+CMGF=1");
        updateSerial();
        mySerial.println("AT+CNMI=1,2,0,0,0");
        updateSerial();
      void smsSend_1(String content) {
        Serial.println("SMS sending");
        updateSerial();
        mySerial.println("AT+CMGF=1"); // Configuring TEXT mode
        updateSerial();
        mySerial.println("AT+CMGS=\"+ YYxxxxxxxxxx\"");//("AT+CMGS=\"" +number+ "\""); //change ZZ with country code and xxxxxxxxxxx with phone number to sms
        updateSerial();
        mySerial.print(content); //text content
        updateSerial();
        mySerial.write(26);
        Serial.println("sent!!");
        recSmsFlag = false; //Reset Rec SMS flag
      void smsSend_2(String content) {
        //wdt_reset();
        updateSerial();
        updateSerial();
        updateSerial();
        updateSerial();
        mySerial.write(26);
      void smsSend_3(String content) {
        updateSerial();
        updateSerial();
        updateSerial();
        updateSerial();
        mySerial.write(26);
      void smsSend_4(String content) {
        updateSerial();
        updateSerial();
        updateSerial();
        updateSerial();
        mySerial.write(26);
      void smsSend_5(String content) {
        updateSerial();
        updateSerial();
        updateSerial();
        updateSerial();
        mySerial.write(26);
      void makeCall(String number1) {
        recSmsFlag = 0; //Reset Rec SMS flag
        mySerial.print (F("ATD"));
        mySerial.print (number1);
        mySerial.print (F(";\r\n"));
        updateSerial();
        onCall_prev_time = millis();
        Serial.print("----Calling to ");
        Serial.println(number1);
        onCall_flag = true;
        //delay(15000);
      String getName(String nameOfuser) {
        String user;
        Serial.print("Get Name is Running ----------");
          if(nameOfuser.indexOf(number_1)>0){
          user = "Rashad"; //name of first user
          return user;
          else if(nameOfuser.indexOf(number_2)>0){
          user = "Hashim"; //name of second user
          return user;
          else if(nameOfuser.indexOf(number_3)>0){
          user = "Rasil"; //name of third user
          return user;
          else if(nameOfuser.indexOf(number_4)>0){
          user = "Anas"; //name of fourth user
          return user;
          else if(nameOfuser.indexOf(test)>0){
          user="Rafi";
          return user;
          else{
            user = "Unknown";
            return user;
      void processMsg(String msg){
        Serial.print(msg);
        Serial.println("process started!!!!!----------");
        digitalWrite(11,1);
        delay(500);
        digitalWrite(11,0);
        if ((msg.indexOf("Stop")>0)) {
            Serial.print("Got ACK from------ ");
            //wdt_reset();
            userName = getName(msg);
            ackFlag_1 = 1;
            ackFlag = 1;
          else if ((msg.indexOf("Check")>0)) {
      //      detachInterrupt(CountPulses);
            Serial.println("Status Test MSG Received --------");
            statusAck = 1;
          else if ((msg.indexOf("Terminate") > 0)) {
            Serial.print("Terminated all notification until next event by ");
            //Serial.println(userName);
            // wdt_reset();
            terminate_flag_1 = 1;
            terminate_flag = 1;
         else{
          Serial.println("Not a admin commend ");
        salmanfaris @rafitc99 last edited by
        Hi @rafitc99, May I know why you are using this same function definition with different function name?
          updateSerial();
          updateSerial();
          updateSerial();
          updateSerial();
          mySerial.write(26);
          //wdt_reset();
          updateSerial();
          updateSerial();
          updateSerial();
          updateSerial();
          mySerial.write(26);
          updateSerial();
          updateSerial();
          updateSerial();
          updateSerial();
          mySerial.write(26);
        rafitc99 1 Reply Last reply Reply Quote 1
          rafitc99 @salmanfaris last edited by
          Sorry, leave that part
          Actually I was using ("AT+CMGS=\"" +number+ "\""); this part and passing number into the funciton. This different functions all are done part of debugging.😀 just checking Is there any problem in string handling.
            salmanfaris @rafitc99 last edited by salmanfaris
            @rafitc99 Ok, are you connecting all the ground as common in the circuit when using the LM2596 buck converter to power up the module/Arduino? and check the resistor that you are using stepdown Tx signal from Arduino to the SIM800L.!
              @salmanfaris Yes. I'm providing common ground. Resistors also working.
                @rafitc99 Great, can you try this simple code that only includes the SMS sending part! if it's working fine with and without the computer connection we can look it to the other parts!
                SoftwareSerial mySerial(3, 2); //SIM800L Tx & Rx is connected to Arduino #3 & #2
                void setup()
                  delay(1000);
                void loop()
                  mySerial.println("AT"); //Once the handshake test is successful, it will back to OK
                  mySerial.println("AT+CMGS=\"+ZZxxxxxxxxxx\"");//change ZZ with country code and xxxxxxxxxxx with phone number to sms
                  mySerial.print("SMS Test "); //text content
                  updateSerial();
                  mySerial.write(26);
                  delay(7000);
                rafitc99 1 Reply Last reply Reply Quote 0
                  @salmanfaris At that time not receiving an actual message. Receiving a blank message.
                    @rafitc99 When powering SIM800L through DC-DC buck alone it's sending a message right?
                      @salmanfaris When connecting with PC. It will work well.
                        @rafitc99 when powering with the LM2596 it's not sending message text right? but sending blank SMS right?
