    How can i define daud rate in avr microcontrollers ?
      Richu Bini last edited by
      while learning the USART communication in avr setting baud rate part seems little confusing to me .
      There are two registers for setting baud rate UBRROH AND UBBRROL
      How Can i use these registers...?
        Hi @Richu-Bini, The Uart Baud Rate Register (UBRR) is used to set the clock for the UART shift registers and For standard crystal and resonator frequencies, the most commonly used baud rates for asynchronous operation can be generated by using the UBRR settings provided by the AVR Datasheet: AVR306: Using the AVR USART on tinyAVR and megaAVR devices
        And you can find the equation from the datasheet to calculate the UBRR values depends on the clock source it has.
        8422ea95-2844-483c-8e41-acab03c9ec41-image.png more details at the AVR306: Using the AVR USART on tinyAVR and
        megaAVR devices
        alt text src: http://www.avrbeginners.net/architecture/uart/uart.html#baud_generator
        resource:
        • https://cache.amobbs.com/bbs_upload782111/files_22/ourdev_508497.html
        • http://www.avrbeginners.net/architecture/uart/uart.html#baud_generator
        • MatjarX is a results-driven web development company in Karachi focused on helping small businesses get online quickly and affordably. We specialize in done-for-you websites built in just 7 days, combining strategic design, technical development, SEO services, website concierge assistance, and growth marketing under one roof. Our team of global professionals works closely with clients to remove the stress of launching and managing a website, ensuring every business has the tools, visibility, and ongoing support needed to grow confidently in the digital world.
