    PCB Design for ESP32 Stand alone module
    pcb esp32
    7
    31
    24678
      Sharmila @kowshik1729 last edited by
      @kowshik1729 Yes i m programming the board first time using arduion. GPIO 0 is low all the time.
        @Sharmila GPIO0 must not be low all the time. It must be held low only for a moment. Because GPIO0 is a boot strap option for choosing between UART download and normal operation. Please refer to the datasheet and search boot strap. And also can you please post a snap of your newly designed board please?
        S 2 Replies Last reply Reply Quote 1
          Sharmila @kowshik1729 last edited by Sharmila
          @kowshik1729 thank you for the hint ! i will check it . schematic picture of my board is given below
          (freesnippingtool.com_capture_20200721122206.png)
          saheen_palayi 1 Reply Last reply Reply Quote 1
            @kowshik1729 sorry, gpio 0 is low only till it is programmed. after that this will disconnected.
              @Sharmila Reviewed your schematics. Have the following doubts
              1. Is this a USB receptacle?
              1. Didn't find any option where you can pull the GPIO0 low and bring it back to normal state. Did you have a jumper connection or button between GPIO0 and GND?
                Sharmila last edited by
                1. no.
                2. we are using jumper for gpio 0th pin. please refer the below image.
                • saheen_palayi
                  saheen_palayi @Sharmila last edited by
                  This post is deleted!
