    PCB Design for ESP32 Stand alone module
    pcb esp32
    7
    31
    24669
      @Sharmila If you're programming the board for the first time using Arduino IDE then you need to burn the bootloader into the bare IC. I have a doubt when you said the IC is not getting programmed even though the GPIO0 is low.
      I wanna know is GPIO0 low all the time or did you pull it low momentarily using a button??
        Sharmila @kowshik1729 last edited by
        @kowshik1729 Yes i m programming the board first time using arduion. GPIO 0 is low all the time.
          @Sharmila GPIO0 must not be low all the time. It must be held low only for a moment. Because GPIO0 is a boot strap option for choosing between UART download and normal operation. Please refer to the datasheet and search boot strap. And also can you please post a snap of your newly designed board please?
          S 2 Replies Last reply Reply Quote 1
            Sharmila @kowshik1729 last edited by Sharmila
            @kowshik1729 thank you for the hint ! i will check it . schematic picture of my board is given below
            (freesnippingtool.com_capture_20200721122206.png)
            saheen_palayi 1 Reply Last reply Reply Quote 1
              @kowshik1729 sorry, gpio 0 is low only till it is programmed. after that this will disconnected.
                @Sharmila Reviewed your schematics. Have the following doubts
                1. Is this a USB receptacle?
                1. Didn't find any option where you can pull the GPIO0 low and bring it back to normal state. Did you have a jumper connection or button between GPIO0 and GND?
                  Sharmila last edited by
                  1. no.
                  2. we are using jumper for gpio 0th pin. please refer the below image.
                  • saheen_palayi
                    saheen_palayi @Sharmila last edited by
                    This post is deleted!
