    GPS + RF433 Not working together.
    2692
      What output you are getting? Just some zeros?
      rafitc99 1 Reply Last reply Reply Quote 1
        rafitc99 @salmanfaris last edited by rafitc99
        @salmanfaris No any output. Arduino not wating for GPS data.Not runing this loop while (gps.available( gps_port ))
          does it return one/true when you are testing only with gps and gps.available( gps_port )?
          rafitc99 2 Replies Last reply Reply Quote 0
            @salmanfaris gps.available( gps_port ) Is not return a True case.
              @salmanfaris for running while(gps.avaible()); MCU need to wait some time. but after adding VirtualWire library it's not waiting for Serial.available()
                salmanfaris @rafitc99 last edited by
                @rafitc99 said in GPS + RF433 Not working together.:
                Then how is the while loop will work? It should return!
                rafitc99 1 Reply Last reply Reply Quote 0
                  did you try manual waiting? Instead of delay, you can use mills, so the background works will keep run.
                    @salmanfaris said in GPS + RF433 Not working together.:
                    Let me try.
                      rafitc99 @rafitc99 last edited by
                      Not working. Same problem.
                        rafitc99 @rafitc99 last edited by rafitc99
                        @salmanfaris It's worked. 😇 Thank you @salmanfaris for your replies.
                        Actually a small change in void loop is the solution
                        void loop(){
                            // Set buffer to size of expected message
                            uint8_t buf[1];
                            uint8_t buflen = sizeof(buf);
                            // Check if received packet is correct size
                          if (vw_get_message(message, &messageLength)) // non-blocking
                            Serial.print("Potentiometer: ");
                              //Serial.print(message[i]);
                              received_number = message[i];
                            Serial.println(received_number);
                              if(received_number == 1){
                                getGpsData();
                        Used two simple if instead of Nested IF. idk what is the problem of first code. Also if I add any delay() inside void getGpsData() function, showing same problem.
